2005 Expedition Starting Noise
Old Jan 13, 2016 | 05:45 PM
WhyFord's Avatar
WhyFord
My 2005 Expedition makes this kind of noise when starting:
Sounds like a tractor. It will quiet down a little bit later. It generates a "bank 2 too lean" code occasionally.
Could any body tell what's wrong by the sound? Thanks!
Old Jan 13, 2016 | 08:02 PM
meborder's Avatar
meborder
Exhaust manifolds? Might explain the code as well.
Sound clips are tough .....
Old Jan 13, 2016 | 09:59 PM
twigsV10's Avatar
twigsV10
Had to use earphones and listen really carefully but I think it sounds similar to my 05 Expedition and exactly like Dads 10 Expedition before I fixed it (i'm not going to put money on it though). They both had an exhaust leak on the #4 exhaust manifold port (The back one on the passenger side) and had an annoyingly loud exhaust tick on start up but Dads eventually also cracked the exhaust manifold between the #4 port and the exhaust pipe flange and sounded awful when the Engine was cold.
Start it Cold then listen at the front wheel wells, A manifold leak will be fairly obvious from there.
Old Jan 15, 2016 | 04:51 PM
WhyFord's Avatar
WhyFord
Thank you very much guys! I will check the manifold this weekend and let you know.
Old Jan 18, 2016 | 05:13 PM
WhyFord's Avatar
WhyFord
Your guys are absolutely right: I found leak on driver side after failed to find anything on the passenger side. Then I remembered I replaced the cat converter on driver side recently and forgot to tighten those bolts. The reason I didn't make the connection right away is it didn't make this kind of noise right away...
Your guys are great and it runs much better now! Thanks!
Old Jan 19, 2016 | 11:04 AM
meborder's Avatar
meborder
Glad you got it sorted out!
Did fixing the leak also fix the code you were having?
Old Jan 20, 2016 | 06:44 PM
WhyFord's Avatar
WhyFord
I deleted the code and let's wait a couple of days to see if it will reappear...
Old Feb 2, 2016 | 07:00 PM
WhyFord's Avatar
WhyFord
Still no code after all these days...
So I think it's fixed, a small leak on the exhaust manifold caused all the problems...
I think we should have a special section under each car/group of cars, called symptoms/causes/solutions. In it there is nothing else but successful fixes for various problems. This way people can go in there, type a symptom and immediately find a solution.
Old Feb 3, 2016 | 12:59 PM
alloro's Avatar
alloro
Glad it is fixed. As far as your suggestion it would be very difficult to implement since there are way too many variables to account for, from vehicle to vehicle, driving condition to driving condition, from driver to driver, etc., I'm sure you get the idea.
thecodemonk
Jan 5, 2017 08:01 PM
graypatrick093
Jul 22, 2015 11:20 AM
Mikey_23_ny1
Jul 7, 2015 08:40 PM
yosemitesamiam
Feb 18, 2009 11:06 AM
Mike-G
1997 - 2003 F150
Mar 10, 2007 08:45 PM
