Sponsored by: Real Truck
2003 F350 Alignment
Old Jan 9, 2016 | 11:41 PM
powersmoke~'s Avatar
powersmoke~
2003 F350 Alignment
I have a 2003 F350 7.3l 2wd drw that I just finished installing a 2 inch leveling kit on the front. They are coil spacers. The reason why I did so, was because I was beginning to not like how bad the fronts dip down on the 2wd. Anyways, I got it up on the alignment lift and obviously it messed with my camber and caster. Quite a bit actually. Front wheels are sitting like \ /. Left camber was +2.7°and right camber was +2.5°. Now I don't know the stock degree on the camber/caster bushings, but could anyone lead me toward what bushing would fix that? Or at least give me a stock size? Would bushings MOOG K80109 do me good? Any info would be great. Thanks.
Old Jan 10, 2016 | 06:46 AM
Irish19614x4's Avatar
Irish19614x4
How did you measure the camber? Never mind I see you posted you put it up on alignment lift so you must have tools to do it. If that is the case how do you have alignment lift but not know how to correct the issue? Just asking I certainly have no idea how to go about checking camber/caster and nor do I know how to correct it. That is why I will be taking my truck to a alignment shop next week to fix any issues mine might have after a 2.5" leveling kit installed the other day.
Old Jan 10, 2016 | 08:41 AM
powersmoke~
Well as far as measuring cambe caster and toe I can do. Its simple. But this is the first time I've ever had to mess with this kind of set up so I have no clue how to adjust or how to calculate the right bushing.
ArcticCircle
Jan 17, 2020 02:16 AM
Quarterwave
Jan 20, 2019 12:30 PM
Nicholas Fluhart
Jul 5, 2018 03:38 PM
Chevra
May 4, 2017 12:38 PM
Fordenthusiasts
Jan 29, 2012 03:34 PM
