exaust question
Old Jan 8, 2016 | 08:40 AM
lowrider50's Avatar
lowrider50
exaust question
I have a 95 F-350 5.8 a40d trans. The Y pipe needs to be replaced. No parts stores have a listing for a 95. They do list one for 88-93 and Ford no longer sells this part. Has anybody run into this problem and if so what did you use.
Old Jan 8, 2016 | 08:58 AM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Check out site sponsors Jeggs and Simmit. Both carry a wide variaty of stainless y pipes made by flowmaster, magnaflow, etc.
Old Jan 8, 2016 | 09:44 AM
78 PEB's Avatar
78 PEB
Or, if you don't want to fork out the $$$ for a stainless one, head to a reputable local exhaust shop and have them fab one.
Old Jan 8, 2016 | 11:29 AM
rla2005's Avatar
rla2005
I few minor corrections:
Your truck has an E4OD transmission, there is no A4OD.
Your truck has an H-pipe. not a y-pipe like the F150/Bronco.
I have no idea why there is no H-pipe listed for a F250/350 beyond 1993. There were no major changes in the frame, engine, etc. until the end of the OBS style truck in 1997. I am not aware the 5.8L equipped trucks used OBD-II powertrain control in Cali. like the 7.5L trucks did (1996-97) so it's probably safe to say the H-pipe for the 88-93 trucks should work on your 1995 model year truck.
Walker makes a replacement under Part# 40585 which would be a plug-n-play replacement since it has the flange to support the oval converter inlet.
Walker 40585
I ran into this same dilemma when I needed to replace the entire exhaust from the manifolds back on my old 1992 F350 w/5.8L engine. I used a Bassani y-pipe designed for a F150 and a universal 3" ceramic hi-flow converter. The Bassani pipe was pricey, but it fit like a glove since the a F350 is exactly the same as a F150 from a cab and chassis dimension viewpoint. I finished it off with a 3" Magnaflow muffler and a Walker 3" tailpipe designed for a Chevy truck. The only mod I had to do was bend the built-in hanger on the tailpipe about 1/2" to line up with the hanger bracket on the truck.
Old Jan 8, 2016 | 02:39 PM
lowrider50's Avatar
lowrider50
exaust question
I called Walker about that part #40585. They said it wouldn't fit but they couldn't tell me why. I agree with you it should work. I went this afternoon and ordered it with the agreement that I could return it if it doesn't fit. thanks. Would rather stay with the stock part if possible,
Old Jan 8, 2016 | 06:12 PM
rla2005's Avatar
rla2005
Keep us updated. Thanks.
thahn1608
Sep 13, 2017 06:33 AM
firewood truck
Oct 4, 2011 09:27 PM
Shade
Jul 19, 2008 11:54 AM
travlnman
3.8 & 4.2L V6
Apr 11, 2004 08:58 PM
shami02
Exhaust Systems
Oct 3, 2000 05:18 AM
