Sponsored by: Real Truck
Track bar drop bracket
Old Jan 9, 2016 | 05:22 AM
Irish19614x4's Avatar
Irish19614x4
Originally Posted by Hoss416
Wow, they must have upgraded the bolts to 1" plus, which is a good thing! As far as an adjustable track bar, I think that is up to the user. My 99 with a 4" worked fine with a drop bracket, my 04 with a 6" was fine too. I'm only about 1,500 miles into a 2.5" on my 15, but it seems to work just fine.
You have photos on your 2.5" kit? Also what size tires you running and is your DRW or SRW?
Also, just curious what 2.5" kit did you use for your 2015?
Old Jan 9, 2016 | 05:25 AM
Irish19614x4
Never mind the photos I see your profile photos, but what kit is that? And your tire size?
Old Jan 9, 2016 | 05:30 AM
Hoss416's Avatar
Hoss416
It's a f250 srw. There is a picture in my profile. When I get home, I could send you a before and after, unfortunately I don't have both on my phone. I used a ReadLift 2.5 front and 3 rear, I needed the extra half inch on the rear for towing my travel trailer. I'm running a 295/70R18 on it now but I might jump up to a 305 70 when my Nitto's are done.
Old Jan 9, 2016 | 05:35 AM
Irish19614x4
That's nice and unlike my truck it already came with the extra 2" or so in the rear being a F350 DRW so my kit was just to level front. I want to run as large as I can with my 17x7.5" OEM rims but I'm afraid unless I find hole in the wall shop that I will only be able to run 285/70/17 on my truck from a reputable shop. We shall see because ideally I would want to go with 35" I just don't think they are going to mount 12.5 width tire on a 7.5" rim.
Old Jan 9, 2016 | 05:36 AM
Irish19614x4
Before and after photos be cool to see when you get time, and thanks!
Old Jan 9, 2016 | 05:39 AM
Irish19614x4
I was also contemplating the idea of pricing some 20" rims with nice tires but not sure they will fit the way my truck sits now or if I would need at least 4" lift. My kit says I can run 35" or 37" but with the 37" I may need modify the truck a little due to rub.
Old Jan 9, 2016 | 05:40 AM
Hoss416's Avatar
Hoss416
I'm not sure about the drw trucks, but I ran these on my truck stock, they are roughly a 34.5 x 11.8 on an 18" rim. I ran the same thing on my F150 with a leveling kit and about 1/2" shaved off the bottom of the air dam. The wore well on the F150 and they are an E rated tire. Cooper makes a similar tire for a few bucks less.
Old Jan 9, 2016 | 06:07 AM
Irish19614x4
Were you trying to provide a link? Didn't come through,......
Old Jan 9, 2016 | 06:08 AM
Irish19614x4
I also think the 18" rims are 8" wide?
250_Metallic
Sep 29, 2017 09:47 PM
Yahiko
Jul 11, 2012 03:58 PM
afonda
May 30, 2012 07:34 AM
oldgameandfishdiesel
Dec 1, 2010 07:15 PM
FTE Ken
1978 - 1996 Big Bronco
Sep 25, 2001 09:45 PM
