Headers
Old Jan 7, 2016 | 10:13 PM
Upfront's Avatar
Upfront
Headers
I'm building a 68 ranger and have already installed a CV Front suspension. I'm ready to do mock up for motor mounts and steering now but want to mock up with headers.im using a 351 w . Hoping someone on here has done this already and can save me some time and money. The engine builder just told me long tube 1 5/8 headers
Thanks ,
Johnny Myers
Old Jan 7, 2016 | 10:21 PM
HIO Silver's Avatar
HIO Silver
Awesome. Go for it.
Old Jan 8, 2016 | 06:02 PM
JEFFFAFA's Avatar
JEFFFAFA
Thanks ,
Johnny Myers
Welcome to FTE!
I don't remember seeing a 351W/C.V. swap header post. If nobody chimes in might I suggest Mustang Shortie headers? These would miss the motor mount stands. Dunno if you're going to have clutch linkage though.
Old Jan 8, 2016 | 07:01 PM
Upfront's Avatar
Upfront
I wll be running a c6 thought I might try some 351w long tubes for a mustang.
Pro max in Alabama is building the motor should have somewhere around the 600 hp range won't really know till its dynoed . Already changed the rear to a coil over ladder bar system.gonna check some threads on here to install a tank under the bed behind the rear axel
Old Jan 8, 2016 | 07:02 PM
Upfront's Avatar
Upfront
Oh I forgot . Thanks for your help
Old Jan 10, 2016 | 03:21 PM
351Cleveland C4's Avatar
351Cleveland C4
A 600hp 351? Holy cow that's gonna be a screamer. Is it going to be a stroker motor or a true 351? Care to elaborate about what's being done to it? I can't imagine a 600hp engine not using 2" primary tubes.
Old Jan 10, 2016 | 05:10 PM
kdaug5's Avatar
kdaug5
Hey I have a 351w with AOD and I'm using the 66-77 long tube headers. I had the Mustang shorties and just switched to these Hedman Bronco headers and they are way better. A good muffler shop can work the exhaust around the tranny mount if your using a C4/AOD.
Good luck on your build
Old Jan 10, 2016 | 10:16 PM
orich's Avatar
orich
The only trouble of having 400-600 hp is have to drive the 25-35 mph speed limits.
Plus you'll be getting 6-8 mpg to drive the same as a vw with 36hp..
Orich
Old Jan 11, 2016 | 12:15 AM
351Cleveland C4
Orich
That's why i find it so ironic when people buy a Shelby mustang or Srt dodge and never even floor it. They drive it more gently than they would a 4cyl econo-box car. If you have a muscle car or hot rod, you're supposed to drive it as such! If I had a mustang (and someday I will) I'd drive the hell out of it!
Old Jan 11, 2016 | 01:18 PM
Upfront's Avatar
Upfront
Trust me I will drive mine that's what it's built for , not tooling back and fourth to the grocery store. 351 c4 it will be a stroker full roller patriot heads. I didn't really understand the small primaries either but that's what the engine builder said to get
Old Jan 11, 2016 | 01:37 PM
351Cleveland C4
427? Smaller primary tubes help with velocity and torque, but high displacement high rpm engines need to breathe! I don't know who your builder is or what his credentials are, but I'd surely be using 2" primary headers. (But then again I'm not a professional engine builder)
Old Jan 11, 2016 | 09:02 PM
IN2FORD's Avatar
IN2FORD
Would you happen to have the part number on the headers?
Barry
Old Jan 12, 2016 | 08:40 AM
Uni Moe's Avatar
Uni Moe
Barry
I don't think kdawg5 has the CV conversion. Right kdawg5? Might make a difference in your case.
Old Jan 14, 2016 | 05:42 PM
IN2FORD's Avatar
IN2FORD
So is anyone running the CV conversion and long tube headers with a 302 or 351W?
Barry
Old Jan 15, 2016 | 08:53 AM
kdaug5's Avatar
kdaug5
Yea no CV conversion for me.
