does it do what it says it does? We get a regular oil change fluid check every three months, just wondering if the tune up fluid stuff is worth it?
(Yes another dumb female driver question
I have a noisy lifter in my engine and it seems to help when I use the Wynn's Engine Tune-Up. And since a can is only a few bucks, I use it every time I do an oil change.
Timothyap5vm: we had a horrible noise like that when we first bought this van last year, the dealer ended up paying to put a new (used) motor in, there was some internal problem they didn't even want to mickey mouse with it.
marie
My engine doesn't make any Klunking sounds but there is a definate audible tapping sound. I don't hear it around town but under hard acceleration onto the highway, between 60-85 km/h, it's bad (even worse in the winter), until I reach cruising speed. But as for the diesel sound, I've never experienced that...it just sounds like Fords underpowered V6
Hope that helps.
