S. California Chapter Join Chapter, Leader:
Another Trailer thread
Old Jan 6, 2016 | 11:18 PM
wpnaes's Avatar
wpnaes
This one is potentially for the Cubs. They need some sort of covered trailer and this one is available for cheap.
I'm not sure what type of braking system this is; air over hydraulic?
Some sheet metal damage, crow bar on the door? A/C? Room for lots of pipes. A real axle, no pumpkin.
Some pics:
Old Jan 6, 2016 | 11:55 PM
r2millers's Avatar
r2millers
I see those are surge brakes. Many boat trailers used those before discs. When you slow the drive vehicle down, the ball pressure initiates pressure on the hydraulic system to activate the brakes, usually drums.
You can see what brake fluid does to paint!
Looks like it needs a brake overhaul as any trailer in CA with a gross weight of 1,500 lbs or more, requiring brakes.
I'm not sure of the original mfg but a very common set up and parts easily available. Fulton maybe? I know Trailerite uses these same parts.
Also, it might be a 2 5/16" ball, not 2" so be careful before hauling.
I'd say, just change the paint from school bus orange to Boy Scout brown and you'll be good to go.
Old Jan 7, 2016 | 12:07 AM
r2millers's Avatar
r2millers
Here's a 2" Atwood replacement head from e-trailer.
You will need to do a good flush and drum brake inspection if you buy this guy.
Old Jan 7, 2016 | 03:50 AM
OldBlackCat's Avatar
OldBlackCat
yeah that's a surge brake system.... it may be money and time (mostly time) ahead to swap that hitch out for a fresh one...
coat of paint would do wonders, and goes without saying some good tires! inspect the wireing and get the brakes up to snuff.... from the pictures looks simple enough.
Old Jan 7, 2016 | 06:02 AM
wpnaes's Avatar
wpnaes
Thanks Bob and Justin, good feedback for me.
Old Jan 10, 2016 | 07:34 AM
wpnaes's Avatar
wpnaes
Visited and took more pics yesterday; plenty of sheet metal to bend back into place and lights to fix.
Old Jan 10, 2016 | 01:24 PM
OldBlackCat
damn its been used! whats the asking price?
Old Jan 10, 2016 | 03:21 PM
wpnaes's Avatar
wpnaes
Lol, I've proposed $200, but it'll take $400 to get it in good shape.
Old Jan 11, 2016 | 02:51 AM
OldBlackCat
since i dont know how the cubs will use it, i cannot say yay or nay on the cost....
Old Jan 11, 2016 | 09:50 AM
bpounds's Avatar
bpounds
Gotta be worth $200, but the labor that could be put into it could be limitless, depending on how good it needs to look.
I think I would inspect it to see if it is going to be weatherproof as is. If not, too much work is needed to fix leaks. If it is, replace that A/C unit with some kind of improvised sky light. Then at least it will be secure storage for their gear. Forget straightening the sheet metal. Too much labor involved.
It is going to need all new wiring and lamp fixtures. And you already know about the need for new brakes. Tires probably. If it has valid registration, that's a big plus. You won't need an inspection.
We had a big issue with storage. No one wanted the thing sitting on their property. Even the church that sponsored the troop was not happy about it sitting on their lot (waffled back and forth on it, once we already had it). Someone donated that enclosed trailer, so zero cost to the troop, and it was till a problem thing at times. Storage, who owns it, maintenance, who is safe to tow it, etc. It was a decent looking enclosed trailer too, but sitting around it still got filthy, cobwebs, leaves, even graffiti. Just some downsides to think about. It sure was nice to hitch up and go. Cut hours off the time involved in an outing.
Old Jan 11, 2016 | 09:55 AM
bpounds's Avatar
bpounds
Another thought on brakes - surge brakes suck hard!
Look into replacing them with standard electric brakes. You can buy complete hub assemblies with brakes already assembled, to fit just about any trailer spindle out there. I would research that before investing anything in repairing surge brakes. You're going to be rewiring the whole thing anyway, so not an issue to include brake wiring.
Old Jan 11, 2016 | 10:41 AM
r2millers's Avatar
r2millers
Pops and me reviewing this morning. One question we brought up was how many other dads will be pulling? If others, each will need a vehicle brake controller vs just the surge requiring the correct ball. It will have a safety brake away switch if someone looses the trailer.
Food for thought.
Old Jan 11, 2016 | 05:04 PM
wpnaes's Avatar
wpnaes
Thanks for all the inputs; all valid points on lots of body ^electrical work, storage, ability to pull with questionable vehicles down the road, and revolving door on owners. Next year I'm out and the next generation of dad's may not want the yellow elephant.
Meantime i'm working down south this week.
tweak1029
All Things Towing
Mar 16, 2016 10:34 PM
GGWild
13
Jul 28, 2013 05:23 PM
spence13e
Dec 6, 2008 11:35 PM
Spirit615
All Things Towing
16
Oct 8, 2007 07:57 PM
slh94150
All Things Towing
May 12, 2004 10:52 AM
