new ecu.question
Old Jan 6, 2016 | 07:55 PM
RadioControlGuy85's Avatar
RadioControlGuy85
new ecu.question
hey guys,
do i need to do a relearn or what?
i cant find a relearn for this.maybe cause not looking for the right stuff.
could someone help me out. its in the truck ready to be hooked up.just wanted to check before i go and start it.
Old Jan 6, 2016 | 08:25 PM
rla2005's Avatar
rla2005
The new computer will have default values in it's memory but there is nothing special to do. Fire it up and drive it.
Old Jan 6, 2016 | 09:49 PM
Conanski's Avatar
Conanski
I think you are confusing a relearn with a refllash. All PCMs have to relearn what the motor needs after the battery has been disconnected for more than 15min, but a reflash isn't needed on a new computer and only OBD2 PCMs can be reflashed anyway so that doesn't apply in this case.
Old Jan 7, 2016 | 05:14 AM
RadioControlGuy85
on the papers that came with it. it saids may need to do the relearn procedure
thats why i was asking
Old Jan 7, 2016 | 07:53 AM
'89F2urd's Avatar
'89F2urd
It's also useful to know that you need your sensors to be in tact and functioning in order for it to learn properly...tps, map, o2
Old Jan 7, 2016 | 09:13 AM
dixie460's Avatar
dixie460
Just drive it like you normally do, that's the best and easiest way. It will eventually relearn all it needs to know. Your idle be a little screwy at first but that will clear up.
Old Jan 7, 2016 | 09:38 AM
rla2005's Avatar
rla2005
X2......
As you drive the truck the computer will relearn and adapt. Nothing special you need to do.
Old Jan 7, 2016 | 09:42 AM
Conanski's Avatar
Conanski
on the papers that came with it. it saids may need to do the relearn procedure thats why i was asking
Yes the PCM will need to relearn so just drive it normally.. that is really the only thing you can do to help. In this case they are telling you that it may take a few drive cycles for the engine to return to optimum operation as the computer learns the details of the engine's requirements, but unfortunately they didn't quite spell that out with the above statement.
Old Jan 7, 2016 | 06:07 PM
RadioControlGuy85
installed the new computer this moring,first turn of the key she fired right up.
the hard to start and cranking forever is gone,also the miss is gone. this thing has been like this ever since my grand dad has bought. glad its running 100% thanks guys
Point Blank
Aug 4, 2012 07:24 PM
Bones&sox63
Sep 24, 2004 02:12 PM
v10kenj
Modular V10 (6.8l)
Nov 1, 2003 04:14 PM
FordCowboy2000
1997 - 2003 F150
Jun 7, 2003 11:39 PM
