6.2L V8 Discuss the 6.2L V8
Drive Shaft
Old Jan 6, 2016 | 01:05 PM
bignast1's Avatar
bignast1
Drive Shaft
Hello all, while trying to diagnose a shaking/wobble i have between 48-52 mph i was looking at my drive shaft. I have what appears to be an aftermarket/custom single piece driveshaft (maybe 5 inches in diameter). I thought these super duties came with a two piece and a carrier bearing? I am the second owner so i am not sure what it had originally. It is the 2012 super crew with the short bed.
Old Jan 6, 2016 | 01:55 PM
airm4n's Avatar
airm4n
My 11 is one piece. I believe the short boxes are one piece and long boxes are 2 piece but I could be wrong.
Old Jan 6, 2016 | 02:08 PM
ATP Pilot's Avatar
ATP Pilot
my CC short bed is 2 piece
Old Jan 6, 2016 | 11:28 PM
Strokin-A-2010's Avatar
Strokin-A-2010
Mines a one piece from the factory.
Old Jan 6, 2016 | 11:43 PM
airm4n's Avatar
airm4n
Maybe they were getting a deal on driveshafts on certain days lol no idea.
Old Jan 7, 2016 | 03:27 AM
Hedgehog1's Avatar
Hedgehog1
My 2016 crew cab shortbed is a one piece. My previous 2005 crew cab longbed and 2002 crew cab shortbed were two piece.
Old Jan 7, 2016 | 08:42 AM
ATP Pilot's Avatar
ATP Pilot
Guys, it depends on a lot of factors...2wd or 4wd, long or short bed, Crew Cab etc.
Old Jan 7, 2016 | 01:11 PM
wrvond's Avatar
wrvond
My 2012 6.2L 3.73 4x4 CC 6.5 bed is a single piece.
So what mods have been installed? If a suspension lift has been installed, there is a new driveshaft that's supposed to be installed. And of course the angle of the pumpkin might need to be adjusted, too.
Old Jan 8, 2016 | 07:52 AM
bignast1's Avatar
bignast1
thanks for all the input. it has a 4.5 coil/block lift in front and 6 inch lifted leaf in the rear. It was doing this shaking/vibration before the lift however. In another thread many people kept pointing to the tires and it is still looking like they are the culprit. I am working with the installer to get 4 new ones. Here's hoping. I definitely have a larger diameter custom/aftermarket 1 piece drive shaft. I crawled under my buddies 2013 diesel and his is a single piece but is slightly smaller in diameter. My front suspension is all good. I will update as soon as we get the new tires (hopefully)
Old Jan 8, 2016 | 09:17 AM
airm4n's Avatar
airm4n
Does it do this while you accelerating through the speed you mentioned or while cruising normally? Could be something to do with a U joint.
Old Jan 8, 2016 | 09:24 AM
bignast1's Avatar
bignast1
It does not do it while i am accelerating through. I settle in and with 1-2 seconds it starts it every time. I feel it slightly at higher speeds on the highway but manageable. The 48-52 is the worst and almost jarring. Even when decel down from 65-70 as soon as it hits 50 it starts doing it and then quickly out of it as i get lower in speeds.
Old Jan 9, 2016 | 08:05 PM
projectnitemare's Avatar
projectnitemare
Short beds are usually 1 piece. Is the lift a kit or something you put together? High speed or low speed vibration? How are the driveshaft angles? Lot of variables here that will cause vibration.
Old Jan 10, 2016 | 09:51 AM
ATP Pilot's Avatar
ATP Pilot
that may be true if you have 4wd.
Old Jan 10, 2016 | 03:33 PM
bignast1's Avatar
bignast1
I put the new rims/tires then i noticed it. The new tires were rubbing so i lifted the truck thinking new shocks might help and it still did it. The only reason i questioned the drive shaft because it is clearly not stock. But it happened before and after the lift on the new tires.
Old Jan 10, 2016 | 05:14 PM
projectnitemare
No lift commercially made lift kits for 4x2s, no issues there. You need to figure is it a high speed (drive line) or low speed (wheel) vibration. Try jacking the rear up and running through the gears. Try it again with the rear wheels off, remember to snug a few lugs to keep the rotors from wobbling. If its indeed drive shaft you need to check the angles and get the shaft rebalanced.
nhill2090
21
Jun 30, 2021 07:06 PM
SRT
2009 - 2014 F150
33
Feb 11, 2020 12:02 AM
kimchiman5150
May 24, 2015 04:59 PM
ebaugh90
6.7L Power Stroke Diesel
May 8, 2011 03:14 PM
War_is_my_Shepherd
Apr 22, 2005 12:25 AM
