DIY Efuel Thread (w/ easy to read parts list)
https://www.ford-trucks.com/forums/1...thread-36.html Couple pics in there...
here are a couple more...
I guess the only one I looked at was the Airdog $719
PureFlow AirDog II Air/Fuel Separation System DF-165 Powerstroke 7.3L
I guess my question is still, is there a difference besides price?
I don't know much about the Airdog system but I don't think it includes much or any of the engine valley plumbing to replace the fuel bowl. So in addition to the Airdog kit you still need to buy a lot of the parts shown on the worksheet which is going to drive the installed price upwards.
Thanks, looks like a very clean installation and it looks like you accomplished one of my goals which is to avoid having the filters exposed and vulnerable to rocks and other hazards.
Darin, I know what you are talking about. I'm in the middle of kluging together my own system, although I cheated and bought parts of a kit. I didn't realize what I was getting into and I haven't even started on the electrical part yet.
I agree on putting all the parts together, I as well lived way out in the stik and had to wait a couple days to get the next piece from summit over and over again, However I wouldn't have done it any other way.
Keep your filter clean, that's about all the modifying you can do to the stock system. The stock system is just fine for stock injectors. A lot of guys claim a snappy pedal, unicorn inmprovements with efuel. Besides the fact of feeding bigger injectors I really did not notice a damn thing. Thought a smoother idle, but i think i was trying to create that in my mind.
So I just saw that Dieselsite has a complete system for around $1500 but doenst look like it comes with the big filters like the others. Does this still use the stock filter?
http://www.dieselsite.com/dieselsite...97ford73l.aspx
EDIT, i finally clicked on the link. The filter is in that drain down fuel/water sep bowl. Doesn't appear to be a dual filter setup.
I will also mention, the biggest problem outside of a quality pump I found with the efuel systems is the oil pressure switch that comes in the electrical part for the kits. I would completely get rid of this function if I were you and run the pump power directly to a toggle switch.
I understand its for safety, but I tied three different switch manufactures, cheap or expensive I couldn't get 2 oil changes out of a switch. Bigger pain in the *** than I was wanting.
At least with a toggle you can flip it off in case of an accident, if the ignition does not do so, yes no Oil pressure is a nice function to have, I'd love to have it if someone made a switch that had a 50 k mile warranty. I'd buy it.
Strictly Diesel has a harness that I ended up purchasing that does just that. There is a relay that pre primes the system for about 10 seconds without pressure provided during cranking or running. It will shut off after 1 key cycle till it sees low pressure oil pressure at the switch. Once you see low pressure oil pressure at the filter base it will kick on the pump via the switch. If your pressure goes to 0 the switch will turn off the pump if the ignition is on. If you remove the switch your pump will run consistently while the key is on. Bypassing the switch with a toggle will allow you to kick it off in case of emergency, thats if you are coherent. That's a risk you have to accept.
#30
Appreciate you posting about the problems you've had, no doubt saved me from some real headaches.
