High Idle topic (again!)
Old Jan 5, 2016 | 12:35 PM
50monte's Avatar
50monte
Hey guy's, I've tested and replaced alot of switches on my 1991 5.8 and its running really well thanks to the advise of some of you guy's. But, at times I still have the dreaded high idle issues, not all the time but it will be idling fine and then change. Last week I tapped on the MAP sensor and it idled down! On the next high idle I did it again! and idled down. It doesnt repeat everytime but sometimes it works.
I attemped to test it but didnt seem to have much luck with that. So I was wondering, could the MAP sensor cause the occasional high idle? thanks
Old Jan 5, 2016 | 02:08 PM
jas88's Avatar
jas88
If it was leaking vacuum, it could.
Old Jan 5, 2016 | 02:22 PM
50monte's Avatar
50monte
No, it's not leaking vaccum. just thought it was strange that it idled down when I tapped on it.
Old Jan 5, 2016 | 03:30 PM
jas88's Avatar
jas88
The main cause of high idle is vacuum leaks.
Old Jan 5, 2016 | 06:17 PM
50monte's Avatar
50monte
Yes, I agree with you on that. But this is different. It can be idling high and for not apparent reason idle down like it should. Almost like it's getting a signal to do so. Come to a stop after driving and it can be high idle, sometime I can tap the throttle and it will idle down. Other times I can switch it off and restart and its correct. So it's not a constant part malfunction. I've set the voltage on the TPS, cleaned the IAC, no Vaccum leaks. Just thinking what part could make this act this way. thanks
Old Jan 5, 2016 | 06:28 PM
rla2005's Avatar
rla2005
Yes, a MAP sensor can cause a high idle. Simply tapping it may mean there is a small crack allowing a vacuum leak to occur or electrically it could have a crack in the internal electronics. It could also be a simple bad electrical connection to the MAP.
How were you testing it before?
Old Jan 5, 2016 | 07:06 PM
fordf350man's Avatar
fordf350man
Others will dislike me for this suggesting replacement before troubleshooting. - Just replace it and see. Its two bolts and its like a $10 part at the auto store. I thought about testing with a meter but once I knew it was a cheap replacement I did it just to move onto the next possible solution. I bought one; replaced it and my truck ran better but was not ultimate cause of my issue(s). I still have the OEM one to go back to if I feel the need but have not yet and too late to return the newer one.
Old Jan 5, 2016 | 07:09 PM
fordf350man
Also if your looking for vacuum leaks. I'd start with the metal can if yours is pre 94 and not the plastic one and just go ahead and replace all the plastic vacuum lines (would not be surprised if one is cracked) with rubber or silicone lines. Of course throw a gauge on it first!
Old Jan 6, 2016 | 07:58 AM
jas88's Avatar
jas88
I agree with ford350man. It's a cheap part that is easy to replace.
brettk1
1978 - 1996 Big Bronco
Feb 23, 2017 08:46 AM
tip49
May 12, 2013 08:09 PM
a1bummer
Jul 9, 2010 06:54 PM
wilevel2
Jul 7, 2009 04:24 PM
