Sponsored by: Real Truck
Turn signal problem
Old Jan 5, 2016 | 10:01 AM
eog037's Avatar
eog037
Turn signal problem
I recently purchased a 1999 Ford F250 Super Duty withba V10. On cold mornings my turn signals won't work but my flashers will. Turn signals only work when the cab heats up and get warm on the inside. I found the flasher that works both the turn signal and Hazzard lights. Right next to the flasher are two little five prong relays. What are they for? And also what could cause my turn signals not to work when it's cold in the morning? your help would be greatly appreciated thank you.
Esteban O Guerrero
Bonita, California
Old Jan 5, 2016 | 10:18 AM
projectSHO89's Avatar
projectSHO89
Probably the multi-function switch or its connectors.
One is the fuel pump relay. The other is the trailer running lamp relay.
Old Jan 5, 2016 | 10:25 AM
eog037's Avatar
eog037
Thank you. I will be working on that after work. Also thank for the info on the two relays.
stecz
Jan 11, 2024 05:35 PM
eog037
General Automotive Discussion
Nov 26, 2016 07:24 PM
98rangerll
Sep 15, 2015 12:37 PM
PeteC
Jan 31, 2005 04:45 PM
