Overdrive Button
Old Aug 8, 2003 | 09:41 AM
live2hunt's Avatar
live2hunt
Overdrive Button
Can anybody give me an informative and inteligent explaination on how to "properly" use the overdrive button on F-Series with auto trans?
MDH
Old Aug 8, 2003 | 01:43 PM
fishin1976's Avatar
fishin1976
Overdrive Button
Turn the OD off when driving in town under 35 MPH or when towing anything. Heavy loads may require that too.
Turning the OD off prevents the trans from shifting more often, decreases heat generated by the trans, and reduces wear and tear on your clutch linings.(bands). The OD gear ratio is not good for towing, Good for longer highway trips, unloaded or lighlty loaded.
If off-roading and constantly changing speeds, turn it off also.
I would not use it when in 4x4 mode either unless I'm crusing snow covered highways in 4high.
Check your owners manual, they have recommendations when and when not to use OD.
Hope this helps.
Old Aug 10, 2003 | 09:01 PM
pfogle's Avatar
pfogle
Overdrive Button
The owners manual will say to tow in overdrive, however if you go to the local tranny shop and ask the best tech in the building he will laugh at you and tell you to go ahead more money for him.
