What I have done to my 1985 F250 5.0L
Items changed on my 1985 F250 5.0L
1. Ford Emblem on front grill
2. Front bumper OEM chrome
3. headlights
4. front marker lens
5. radiator overflow reservoir.
6. windshield washer motor
7. radiator cap
8. water pump
9. fan clutch
10. radiator hoses
11. thermostat
12. EGR Valve
13. spark plug wires
14. spark plugs
15. valve cover gaskets
16. fuel injectors
17. fuel pressure regulator
18. vacuum reservoir
19. AC Dryer
20. blower motor
21 battery
22. master cylinder (brake)
23 vacuum brake booster
24. master cylinder (clutch)
25. disc brake calipers
26. front disc pads
27 front brake hoses
28. instrument panel (complete) with Tach.
29. installed clock
30. dash pad overlay
31. Alpine stereo with polk speakers
32. throttle linkage cover.
33. retractable work light (OEM)
34. window cranks
35. door & window weather strip seals
36. door latch bolts and bushings
37. carpet molded
38. dome light lens
39. glove compartment lid
40. AC vents
41. replaced ***** on AC heat/fan
42. clutch & brake pedal pads
43. intermittent wiper switch
44. clutch switch
45. fuel selector tank switch
46. fuel selector valve
47. fuel pump
48 fuel line
49. fuel tank sending units front and rear
50 fuel tank pickup and screens
51. main fuel filter
52. bed liner (OEM)
53. tailgate
54. tail light assy.
55. rear bumper chrome (OEM)
56. installed U-Haul receiver hitch
57. license plate lights
58. rear brake shoes
59. rear brake cylinders
60. rear brake hose
61. drive shaft u-joints
62. clutch pressure plate
63. clutch plate
64 clutch release bearing.
65. pilot bearing
66. flywheel & ring gear
67. clutch lever dust boot
68. engine belts
69. tailgate latch assy. and handle
70. tires
71. rear view mirror
72. oil & filter
73. fuel rail clips
74. windshield wiper blades
3. headlights
7. radiator cap
8. water pump
9. fan clutch
10. radiator hoses
11. thermostat
12. EGR Valve
14. spark plugs
16. fuel injectors
19. AC Dryer
20. blower motor
21 battery
26. front disc pads
29. installed clock
34. window cranks
37. carpet molded
38. dome light lens
40. AC vents
44. clutch switch
47. fuel pump
48 fuel line
52. bed liner (OEM)
53. tailgate
60. rear brake hose
63. clutch plate
65. pilot bearing
68. engine belts
70. tires
72. oil & filter
73. fuel rail clips
fordzilla01
10-07-2008 01:38 PM
