Fuel soaked clutch???????
Last week was kind of slow at work so I decided to do some maintenance on my truck. It has 150K miles on it and still on the original water pump. I replaced the water pump, T-Stat, fan clutch, belts and hoses. Changed oil, filter and trans oil.
Was on the way to a job monday, climbing up to Tehachapi pass at 4400 feet when my clutch started slipping. It would not take full throttle in high gear but if I dropped down a gear would maintain 50mph on the grade. Got to the top and pulled off the freeway and at the end of the offramp tons of smoke engulfed my truck. Opened the hood and found the fuel tube from the fuel filter to the right head had broken and gobs of fuel was running down the back of the engine. Looked at the fuel gauge and realized I used 1/2 of my rear tank to go 45 miles.
Fixed the fuel line and limped on to my job. When I got home I ordered a clutch kit from Carolina Clutch. Worked around town tuesday, wenesday and thursday when my clutch finally arrived. But by thursday afternoon my clutch was working fine again.
Is it possible the fuel saturated the clutch plate and then burned itself clean again? I only have 65K miles on this clutch and do not have the time to take the truck off the road for a couple of days. I plan on waiting till I have some slack time at work and then change it.
Been there. I burned the fuel off my clutch by starting hard on a steep hill about ten times in a row. The problem is the fuel washes the lube out of the throwout bearing and the factory pilot bearing. The squeek will start soon.
Make SURE you put a Kevlar bushing instead of the pilot bearing. The bearings fail. The bushings last longer than a clutch.
yeahoner
05-14-2022 09:10 PM
yeahoner
06-16-2015 07:13 PM
GiantPinkMonkey
12-11-2013 09:30 PM
Fordbronco69
12-13-2012 07:54 PM
chrisginco
09-03-2012 07:53 PM
