Coolant level
Old Jan 5, 2016 | 08:32 PM
madpogue's Avatar
madpogue
Originally Posted by Jeff heine
Umm???? What???? I have the clear jug mounted on the fender well
Do you have a radiator cap, or is the pressure cap on the jug?
What temperature thermostat did you install?
Old Jan 6, 2016 | 09:23 AM
nossliw's Avatar
nossliw
Sounds like you have the early brass style radiator...
Early style solid brass radiator 94-early 95with overflow tank
95-97 Aluminum core and degas bottle that is pressurized when hot.
Old Jan 6, 2016 | 09:27 AM
nossliw's Avatar
nossliw
Regarding cooling system temperature, if its on the O that's absolutely fine. Has nothing to do with coolant but more so your thermostat, Mine runs below the N in the winter unloaded. Back when it ran at R or in the middle it would get waaaay too hot when pulling heavy loads in the summer. Standard Ford OE thermostat is 192 degree, they make a 203 degree, but I actually run the terminator thermostat to keep it cool.
On a side not from what you said 22 qts was your cpapacity with the brass style system. Both setups cool just fine.
Jeff heine's Avatar
Jeff heine
Mine is the second picture, with the pressure cap
Old Jan 6, 2016 | 10:37 AM
nossliw's Avatar
nossliw
Ok well all I can guess is the block wasn't fully drained. If there is that much air in the system the first time you got it to temp it would have spewed all over. I wouldn't worry about it.
Phoenix02
Aug 24, 2018 08:41 AM
Deuce40s
Nov 23, 2014 04:22 PM
rashdabull09
Jan 5, 2013 09:07 PM
LRMetric
Sep 26, 2012 09:51 AM
MRKnight
General Automotive Discussion
Jun 16, 2006 11:22 PM
