Knock Sensor Replacement 95 F150
Old Aug 8, 2003 | 09:06 AM
rcnuti's Avatar
rcnuti
I would like to have some help in finding where the knock sensor is on my motor. I have a hanes manual, which says that it is on the manifold. It is not specific whether it is on the intake or exhaust, and doesn't have a picture where it is. I bought the new part so that I would know what to look for, but I still can't find it.
The pickup is a 1995 F-150 with 4.9 straight six, 2wd, standard transmission, and EEC-IV.
Thanks in advance for any advice or past experience with these.
Old Aug 8, 2003 | 01:17 PM
rcnuti's Avatar
rcnuti
I searched this forum and found where somebody else was looking for part location using Autozone.com. It indeed worked.
The knock sensor on the 4.9 straight six is in the engine block just to the right of the bottom part of the ignition coil.
I hope this helps somebody else.
Old Aug 10, 2003 | 09:50 PM
steve83's Avatar
steve83
Start at the big square connector beside the engine bay fuse block, and follow the harness onto the engine, looking at each branch. Eventually, you'll find the 2-wire connector with Y/R and Gy/R wires, which is the KS.
ModifierMR
38
May 2, 2024 11:52 PM
topcopsr
Dec 28, 2019 12:40 PM
danjohnson67
Mar 3, 2016 04:29 PM
bartlettf150
May 22, 2015 09:10 AM
bigcountry25
2004 - 2008 F150
May 7, 2014 09:06 PM
