Sponsored by: Auxito
seized engine?
Old Jan 3, 2016 | 11:33 PM
Spray Wash's Avatar
Spray Wash
seized engine?
Truck in question is 2002 F150 4.6 with 150K miles. Crew was on interstate tonight driving 65 MPH and truck shut off. They called me out to trouble shoot. Engine had oil (was a quart low) and will not start. Starter engages but will not turn motor over. Had truck towed back to my shop. I removed belt just to see if it may be a locked up pulley i know, long shot)... it was not.
Employed called a shade tree mechanic he knows and trusts. He said was likely a broken timing chain and that is a common problem in 4.6. Said locked engine is probably because broken chain is wrapped around shaft. When I turn key fan does move about 1/4 inch.
1) Does this sound like a possibility or even a plausible explanation ? Just trying to verify the information this guy gave me before I hire him to explore and replace.
2) If this is the case, would a repair be advisable, or is engine likely shot and i should just replace it?
Thanks in advance for your help!
Old Jan 3, 2016 | 11:47 PM
brokenleg's Avatar
brokenleg
put a breaker bar with a socket on the crank bolt. see if it turns?
Old Jan 4, 2016 | 12:51 AM
Spray Wash's Avatar
Spray Wash
Sorry to sound like such a moron, but by crank bolt, do you mean the pulley on the crankshaft at bottom of engine? If it moves what does that mean?
Old Jan 4, 2016 | 10:04 AM
blupupher's Avatar
blupupher
Yes, the crank bolt is the bolt on the crankshaft.
If it turns, then the engine is not locked up, but does have some issue since the starter will not turn it over.
If it does not turn, probably time for another motor.
Old Jan 10, 2016 | 04:24 PM
Spray Wash's Avatar
Spray Wash
Pulled front of engine off, turns out the right timing chain had eaten into the block/oilpump area. that engine is wrecked...oh well.
obscurity
Feb 8, 2015 03:10 PM
ms061352
17
Jul 28, 2013 01:55 PM
GodBlessOurTroops
1997 - 2003 F150
May 13, 2013 05:07 AM
maestro1024
30
Jan 29, 2013 05:06 AM
Kendrick
May 14, 2011 03:15 PM
