1984 F150 4.9l will not even try to turn over. First time it happened, I replaced the ignition switch and it ran fine for 2 months. Having same problem so I've replaced ignition switch again and it tried cranking until battery died. Charged battery and now won't even try with the new ignition switch. Tried installing push to start button but I cant seem to get that to work either. Any advice.
Changed out as follows: Starter, starter cables, solenoid, solenoid cables, battery and battery cables, alternator, all belts, all hoses, heater core, water pump, thermostat, radiator and radiator clutch fan, spark plugs, fuel filter.
Given that you've addressed most of the electrical, have you looked at fuel delivery (or lack there of) ? As you may well already know...fuel,spark,air.....run. Is it a DSII Ignition? kinda assuming as mine....was.
I'm having this exact problem. Push to start will not turn the engine over for me. I'm going to replace the ignition switch and see how it works. I also bypassed the key by running a push button starter with one wire from batt(+) and other to solenoid.
Good luck, I don't understand why or how the ignition switch keeps dying or shortening maybe. Not sure if I can test them?
Automatic or manual transmission? With manual, there is a safety switch such that the clutch has to be fully depressed for the starter motor to be able to be energized. If the safety switch goes out of adjustment or completely fails, the starter will be "dead".
automatic transmission, would the voltage regulator keep it from even trying to fire over?
If you can't get the engine to spin over. The first thing to do is bypass as much as possible by bridging the 2 large posts on the fender mounted solenoid. Use something metal large enough to carry as much current as the battery cables.
Your automatic transmission also has what is referred to as a neutral safety switch, so the engine will only spin in park or neutral.
Interesting you mention that, my gear indicators don't move when I try and change gears between park, neutral, and drive. Would that safety switch keep it from trying to start?
Yes the safety switch, if not operating properly, would certainly stop the engine from spinning over.
I'm not familiar with how the safety switch is set up on that truck, but it should have one. The fact that your gear indicator needle doesn't move may not even be related to the safety switch.
The gear indicator has nothing to do with anything - it's just an orange needle on a spring. The NSS is on the side of the transmission and is usually combined with the backup light switch; the red/light-blue-stripe wires are what you're interested in, they feed power to ther starter relay wtih the key in START and the NSS breaks that circuit if the transmission isn't in P or N.
Okay, I will change out the neutral safety switch and pray that fixes it. Any other advice as to why it won't start?
No, don't throw parts at it! Get yourself a meter or test light and test for voltage; don't throw parts at it and pray that something fixes it, that's just stupid... do some actual diagnosis....
