Ok lets pretend that I have all the money I need to make my truck the way I want.
lets start with a 351 windsor stroker 392 short block.
now U guys build me the rest.
If it matters I am gonna have a 4spd granny gear and 4.56 gearing. Remember MONEY IS NO OBJECT
Well, depending on how the truck will be used, you'd probably want to start with the Cam shaft since it's sometime refered to as the "brain." I like the Comp Cams Xtreme Energy series. Then throw in a set of lifters.
If money were no object I would go to coast high performance or coasthigh.com and order a 427 small block efi that puts out over 500hp now that is a dream.
Originally posted by jwtaylor If money were no object I would go to coast high performance or coasthigh.com and order a 427 small block efi that puts out over 500hp now that is a dream.
umm lets get some gt40 cast iron heads, before i go any more is weight a problem? it 's not GREAT!, some 10- 1 pistions, 10-18psi boost super charger, gotta be efi, and chang out fuel injectors to the ones they use in air carft so u can burn 100 low lead mixed with some nitro 50/50 is good, and go with a huge lift crane cams and get rid of that tranny, if wieght isn't a problem get a c-6 trans with some other trans innards( cant think of make right now) and have some fun
