Leaky Carb
Old 12-30-2015, 01:58 PM
kennyfzj80's Avatar
kennyfzj80
kennyfzj80 is offline
Leaky Carb
Having some problems starting the car. I have to start it with starter spray and it idles rough.
When I put it in gear it stalls.
Taking a look at the carb, I see that it is dripping from there.
Where is it coming from?
Old 12-30-2015, 05:07 PM
fordman75's Avatar
fordman75
fordman75 is offline
It hard to tell from the picture, but it appears to be throttle shafts are leaking.
Old 12-30-2015, 10:50 PM
kennyfzj80's Avatar
kennyfzj80
Here is another pic.
Old 12-31-2015, 12:41 AM
fordman75's Avatar
fordman75
Yep throttle shafts are leaking. To fix that you'll need to rebuild the carb and either have bushings installed on the throttle shafts, replace the whole base plate assembly or change carbs.
But the leaking throttle shafts shouldn't cause a hard starting problem. They would just cause fuel leaks and vacuum leaks. Which may cause rough idle and some other minor driveability issues.
For the hard starting problems I'd be looking at the choke, or a fuel supply issue ( plugged filter, weak/bad fuel pump, crap in the carb plugging stuff up, etc. ) .
rogerlwii
20
06-12-2016 09:09 AM
jerd_hambone
04-25-2012 10:23 PM
jjurva
12-07-2011 10:20 PM
Broomfieldbum
09-17-2010 08:36 AM
ghunt
General Automotive Discussion
11-18-2007 12:42 AM
Quick Reply: Leaky Carb
