No Power
Old Aug 7, 2003 | 10:18 PM
pl50636's Avatar
pl50636
Unhappy No Power
Greetings to all the Great FORD Lovers;
I have a 1988 Ford E350 Dually with a 460MPI/C6 that hauls my fifth wheel trailer.
My problem is that when the engine heats up the response from the throttle from a stop and trying to get up some speed from any speed when you mash the peddle it falls on its face until it catches up with itself. When cold runs great.
I put on a flow master mufller with 3" exhaust after the cat.
It has a K & N filter, had code 32 in it, replaced egr and evp, no change. Took it to the ford dealer all test were "inconclusive"
another words they found nothing wrong with it.
Any help from you would be awesome
Thank You Very much
Old Aug 10, 2003 | 02:25 AM
Mark@Q.Cove Auto's Avatar
Mark@Q.Cove Auto
No Power
try undoing the exhaust in front of the cat and then take for a drive, maybe a plugged Cat.
Old Aug 10, 2003 | 04:44 AM
pl50636's Avatar
pl50636
No Power
The cat has been hollowed out, but thanks for the reply.
Old Aug 10, 2003 | 01:15 PM
Domenico's Avatar
Domenico
No Power
After replacing the egr and the evp did your code 32 go away? I like to start with fuel pressure / codes/ and ignition system / what did ford have for test results?
Old Aug 10, 2003 | 08:55 PM
pl50636's Avatar
pl50636
No Power
code 32 went away, ford stated fuel pressure was between 30 and 70 psi, no codes showing
Old Aug 10, 2003 | 10:17 PM
f350bronco's Avatar
f350bronco
No Power
If the engine runs great when cold but has no power when hot, I would replace the ECT sensor. If the sensor is reporting the engine is always cold the computer will supply the correct fuel when cold but be pig rich when hot.
Just my two cents...
John
Old Aug 11, 2003 | 12:27 AM
Domenico's Avatar
Domenico
No Power
"Big bronco" has got a point, if you dont have meter to check it they are cheep just replace it. But thats a big spread on fuel pressure test results, do you see black smoke out the pipe or a rotten egg smell when its acting up. Any other new habits when it 's not running properly? ( very important when trying to diagnose) Domenico...
Old Aug 12, 2003 | 02:06 PM
pl50636's Avatar
pl50636
No Power
Bronco,
I put an etc sensor will let you know how it runs, need to give good test.
Domenico,
No black smoke or rotten egg smell,
thanks for asking
pl50636
I do have another ? Why is there a restriction at the intake, I am talking about the funky looking twin horn piece, what does it do and why is it there.
Old Aug 12, 2003 | 05:14 PM
f350bronco's Avatar
f350bronco
No Power
I think this may be the intake air baffle. It is supposed to reduce the air sucking noise.
John
Old Aug 18, 2003 | 01:43 PM
pl50636's Avatar
pl50636
No Power
Well I put in the etc sensor, we went for a 400 mile road trip, and the engine ran great while the engine temp was even cooler. Thanks for all your help
Pete
Old Aug 30, 2003 | 12:22 AM
JJ_00's Avatar
JJ_00
No Power
John
That is its intended purpose, but all it really does is choke off your engine. I cut the horns off of mine and left just enough on to clamp the hose to. It made a world of difference, on take off and on high end.
Josh
'90 F-250 460 w/ZF
