Oil & Lubrication
Best Differntail Fluid
Old Aug 7, 2003 | 09:57 PM
COhunter's Avatar
COhunter
My truck has an 8.8 3.55 in the rear (not limited slip) and a Dana 44 in the front.
What weight and brand do you guess recommend for each one ?
Old Aug 8, 2003 | 12:43 PM
jimandmandy's Avatar
jimandmandy
If cost is no object, Motorcraft synthetic from the dealer is real good, as are the RedLine oils. I use Mobil One because it is available and resonably priced. If you look at the manual, the Dana takes a different spec than the Ford axle. It is a splitting hairs type difference, something like 75W-90 in one and 80W-90 in the other. If your seals are old, synthetic may find leaks that you did'nt know you had. This did happen to me on a GM axle.
Jim
Old Aug 8, 2003 | 02:53 PM
knucklehead11's Avatar
knucklehead11
why are differential fluid viscocities so high?
Old Aug 8, 2003 | 04:36 PM
John with beastly 302's Avatar
Gear lubricants have high viscositys because the diferntal sees high temps and shear forces.
Old Aug 8, 2003 | 05:31 PM
knucklehead11
OH, okay
Old Aug 10, 2003 | 01:06 PM
jimandmandy
There is a different SAE viscosity scale for gear oils than motor oils. SAE 70 motor oil does not equal SAE 70 gear oil at the same temperature.
Jim
Old Aug 11, 2003 | 06:22 AM
DOHC's Avatar
DOHC
FWIW the absolute best mineral gear oil is the Chevron . It's early , I can't think and gear oils not my favorite topic but that stuff won new product of the year either last year or the year before. It has a Timken load rating of 70 lbs vs some other at mere 45-50 ratings .
I like Jim-n-mandy's Motorcraft synthetic 75-140 . It is made by Conoco and is a 100k lube .
For the most part leaks usually associated with synthetics in gear boxes or differentials ae viscosity related as in too thin with somewhat worn seals or older ,hardened and cracked seals .
For example , the Redline MTL is the equivelant of a 5/30 motor oil . Even the MT-90 is a 14 centistroke lube for an approximate 40wt.
dakota-boy
Jan 2, 2011 10:18 PM
spatts
2004 - 2008 F150
Apr 19, 2009 07:55 PM
jberylecrider
Jul 31, 2002 05:05 PM
vinny8
May 2, 2002 10:29 PM
8RC8BA
Dec 24, 2001 04:55 PM
