TPMS Adjustment?
TPMS Adjustment?
Hello all,
Just got new tires installed on my truck and they are very wide. (Installed on factory 20's.) Truck suggests 65 PSI to satisfy the lights, but I'm afraid the tires will wear unevenly at that pressure.
Is there anyway to train the band sensors to a lower satisfied pressure? I see some reset procedures, but does this just reset to stock specs?
Thanks!
Thanks!
This is also true on my 2008 so I'm pretty sure your 2009 will be the same.
You can get Ford to change the values with IDS. If you know someone with an IDS or similar, they can reprogram the values also.
Certainly worth a shot. With the computer looking for 65 psi on my truck, I can go as low as 58 psi without the tpms triggering. My preference would be 45-50 psi for my unloaded truck.
There is a 35-40 buck TPMS tool that will retrain those tire pressures: . Oh and it might take a couple of attempts to get the truck's computer to take.
(Oh and please don't tell my tires that they can't be retrained as I have them all set at 60 psig for the winter.)
There is a 35-40 buck TPMS tool that will retrain those tire pressures: Amazon.com: Motorcraft TPMS19 Remote Tire Pressure Sensor: Automotive. Oh and it might take a couple of attempts to get the truck's computer to take.
The instructions for the TP19 - they have to be downloaded from the 'net. Here's one set of instructions that is similar to the Ford version :How to Train Ford Tire Pressure Monitior Sensors TPMS | eBay
