Dent Electric Fan Conversion
Old Jan 25, 2016 | 07:36 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by Choppermike
I also am needing to go to an electric fan on my 78 - 351w due to having no shroud on my clutch fan and heating up at idle. I want to use the Mark 8 or Thunderbird style which should be readily available here in the yards in my area. My question here is what is the easiest fan controller option. You guys talk about a toggle switch, but Is that just an override? I am clear on the fan and install but need help on the controller. Thanks, Mike
A coupla ways to go about it... first is to use two temperature switches... one for the low speed/low temp and the other high speed/high temp. The links in the Tech Info Compilation provide background.
The other is to use an actual (electronic/digital) controller like that offered by Hayden and others.
DIGITAL FAN CONTROLLER
Hayden - 2-Speed 2-Fan Controller
Personally, I would stay away from any that uses a probe stuck between the cooling fins... notoriously inaccurate.
Visit Hollister Road for a one-stop shop or at least to get an understanding of what is possible: https://www.hollisterroad.com/browse?category=5098
Old Jan 25, 2016 | 07:47 PM
Heliguy's Avatar
Heliguy
These are the diagrams I used for mine. I did 2 fans independently wired to a relay in case one burns out. I also had a switch in the cab. Easy install following these instructions. Good luck.
http://www.davebarton.com/pdf/coolingfandiagrams.pdf
Old Jul 24, 2017 | 12:05 PM
F-250 restorer's Avatar
F-250 restorer
I working on a little book about e-fans, so this post caught my eye. With the Lincoln/cougar/mustang fans that you mentioned, there are many types. Some, from the 90's, have two wires. They are variable speed fans, speed controlled by the computer. Some are two speed, which have 3 wires. I would only say to avoid the 93--96 fans as they are slow, 1100rpm on low. Whereas the 97--98 fans spin 1800rpm on low.
If you want to use the variable speed units, use a Delta Current Control control unit. But there's a wait time, and about $100 price tag. Or... contact The Fan Man, and get a Spal controller for less, but DCC has a better reputation.
A Taurus or Volvo fan (Ford owned Volvo) would work fine for you as well.
Here is a link for the least expensive route, the one I use:
This video shows the volvo fan and the controller ($15 from a j/y). The following links are rather boring since the photos are now dead, due to photobucket now wanting to charge to host them.
http://www.rx7club.com/showthread.php?t=839089
http://www.nastyz28.com/forum/showthread.php?t=200028
http://www.pirate4x4.com/forum/gener...ication-2.html
The Lincoln/cougar/mustang fan uses 26-28 amps on low, and has a 37-40 amp spike at start up.
The quality of the wiring (10g) and relays is very important for these fans, and for your electric system. It's not fun to fry wires. Make sure you have about a 130 amp alternator to run the run and the rest of your vehicle.
Old Jul 24, 2017 | 05:20 PM
Justin Jones's Avatar
Justin Jones
Thanks for the links/video. I've done a fair amount of research since then but the progress on the '75 is nil. Too much other stuff going on.
On another note, I have talked to Brian Baskin of DCC on the phone. He's seems to be a really nice guy. I know he gets a bad rap but mainly just due to the wait time. As of when I called and talked to him, 3 weeks which is nothing to me.
CdnWillyG
13
Aug 21, 2020 04:35 PM
Skandocious
May 25, 2010 03:59 PM
Rat A Tat
May 10, 2003 10:27 PM
Big Hands
18
Apr 30, 2003 02:27 PM
Smason
Aug 28, 2002 03:42 PM
