Motor died??
Old Dec 28, 2015 | 10:39 AM
adampeel85's Avatar
adampeel85
Motor died??
So I had my truck sitting in my driveway idling while I loaded some wheels in the bed. It slowly died off from what seems to be fuel loss. I have a see through fuel filter at the carb and it was dry.
I flipped the switch to the auxiliary fuel tank and went to crank it and it seems like the motor won't turn at all. What are the chances the motor seized from running lean that little bit?? The truck was more or less cool as I had just started it probably 10 mins before.
390 motor.
Old Dec 28, 2015 | 12:26 PM
TheMonson's Avatar
TheMonson
Bad alternator + dead battery?
Old Dec 28, 2015 | 12:44 PM
adampeel85's Avatar
adampeel85
Unfortunately I think it's much deeper then that. It could be possible that my starter died at the same time it shut off maybe but I put the jump pack on it and nothing. Battery is new
Old Dec 28, 2015 | 01:28 PM
Truck Noob's Avatar
Truck Noob
we could use more info.
does it turn over?
mechanical or electric fuel pump?
did you check fuses?
are you getting fuel before the fuel pump?
Old Dec 28, 2015 | 01:32 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Slowly dies off sounds like fuel issue and not electrical or a seized motor. Electrical issue is a quick shut off. A seized motor is usually preceded by a knock, rattle, thump or bang, so I doubt it is seized.
Get a breaker bar and the correct socket for the crank pulley bolt (13/16 or 15/16?) and turn it over (clockwise) just a bit by hand, to make sure it is not.
Double ck your battery terminals and your fusible link. Then pull the starter and take it and get it bench tested at a local parts store.
Clear filter will not always be full of fuel. Could of been a fuel filter that is clogged up or a fuel pump that dies.
Troubleshooting so start fuel and elec issues at the same time is a PITA.
Old Dec 28, 2015 | 03:19 PM
adampeel85's Avatar
adampeel85
Thanks. Yea I'm thinking it's the starter too
Old Dec 28, 2015 | 03:29 PM
46Whizzer's Avatar
46Whizzer
I had a starter go out on me completely out of the blue the other day too.
It cranked up fine that morning, I drove to napa to order something unrelated, went to start the truck and it was stuck solid.
For some reason the bendix went bad and got caught in the flex plate.
Old Dec 28, 2015 | 05:15 PM
adampeel85's Avatar
adampeel85
FIXED!
Was the starter. $48 and an hour later she's good as new.
Never had a starter go out like that before. Kinda threw me off at first.
Thanks for the help
Tylers
Feb 9, 2009 03:29 PM
damnedin82
39
May 2, 2008 10:27 AM
Cecil501
18
Jul 14, 2006 06:53 PM
blofish4
Oct 28, 2005 05:58 PM
mattselland
17
Jul 17, 2005 05:55 PM
