Stalling when accelerating
Old Dec 27, 2015 | 08:02 PM
frncfish2's Avatar
frncfish2
Been a ford truck buff all my life and never ran into this. 1972 ford truck stalls when I accelerate on the gas petal. 2nd rebuilt carb on it. Could this be the vacuum advance? Can anyone help me out on this ? Thanks...
Old Dec 27, 2015 | 08:27 PM
351Cleveland C4's Avatar
351Cleveland C4
Vac advance possible. Where's timing set?
Old Dec 27, 2015 | 10:26 PM
frncfish2's Avatar
frncfish2
I am going to check it out on Tues, my buddy is working on it . Thank you , I will let you know what I find out ... fish
Old Dec 28, 2015 | 01:42 AM
HIO Silver's Avatar
HIO Silver
Auto or manual trans? Check for vacuum leaks? Check for a clogged fuel filter?
Old Dec 28, 2015 | 10:39 AM
Southern24's Avatar
Southern24
Had a similar problem on my 72 360 just last week. Thought it was the carb. I had just recently rebuilt carb, new points, condenser, cap, and button. Was running great. Went out to drive it and I couldn't keep it running over an idle. Rev it up and it would spit and sputter and backfire. Finally narrowed it down to the condenser that i had just replace not a month ago. Cheap part to try. Just my .02
Old Dec 28, 2015 | 11:22 AM
frncfish2's Avatar
frncfish2
Thanks Southern, I carry a few with my 1971 F250 4x4 as this has happened to me. They just don't make stuff like they used too. I will keep you all posted as I move along with it Thanks all.. fish...
Old Dec 28, 2015 | 11:23 AM
351Cleveland C4
Condensers have been the number one culprit of all running problems lately. I tell everybody to get a pertronix kit.
Old Dec 28, 2015 | 12:02 PM
TeachNlive4ever's Avatar
TeachNlive4ever
2X pertronix kit part # 1208 if memory serves me correctly. I'm old so I don't put too much stock in it
Old Dec 29, 2015 | 04:32 PM
JEFFFAFA's Avatar
JEFFFAFA
If you don't go Pertronix go to your local Ford dealer. Ford V8 (single point dizzy) condensers are part number C9AZ12300A (DC-13A). Still available.
Old Dec 29, 2015 | 05:54 PM
BobbyFord's Avatar
BobbyFord
2bbl carb or 4bbl?
Old Dec 29, 2015 | 06:06 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by instig8r63
2bbl carb or 4bbl?
On his other thread he mentioned Holley 4V. And after installing it is when the problem started. I asked quite a few questions about it on that thread Bobby.
Old Dec 29, 2015 | 08:33 PM
frncfish2's Avatar
frncfish2
Thanks for the part # I will hit ford dealer tomorrow and get the pts also. I am believing more and more the carb is under jetted on my 1971 4x4 with the holly 4bbl... fish...
Old Dec 30, 2015 | 08:35 AM
frncfish2's Avatar
frncfish2
Worked on the 1972 today, fires right up when cold, sounds great until the idle comes down (hot air choke on it)then is either dies , like shutting the key off or rough idle until it quits. Air fuel screws are approx. 1 3/4 turns out. Can keep it running long enough when warm to even check the timing. This one is really driving me nutts. Any one have any ideas? thanks again for the help guys... (This has a 2 bbl carb on it)
Old Dec 30, 2015 | 01:03 PM
JEFFFAFA's Avatar
JEFFFAFA
Yep. Change the condenser. There was someone else on here a while back with the same symptoms. Must be a certain engine/dizzy/condenser temp that made his and yours go wacky. This is only one of the symptoms. As Garret said, condensers have been the #1 culprit as of the past couple of years. Whether it be new, used, or new in a replacement Dizzy.
Old Dec 31, 2015 | 09:51 AM
frncfish2's Avatar
frncfish2
nt ahead and ordered the Pertronic kit , i'll ep you posted. Thank you all.. fish...
