51 aluminum fuel tank question
I'm to the point of needing a fuel tank. I've looked at the mustang setups but think I want to go with an aluminum tank. These are the two I'm looking at, does anyone have any experience with either one or another recommendation?
48-60 Ford Truck Fuel Tank
Or
1948-60 Ford Pickup Under Box Aluminum Fuel Tank - Free Shipping @ Speedway Motors
Thanks,
Matt
Or
Thanks,
Matt
fuel tank
I can see that you want an aluminum fuel tank, but I installed a steel 20 gallon tank designed for a 1973 Chevy C10 or Blazer that fit my 51 perfectly for under $200 new. Came with straps and sending unit. Had to make two mounting plates for each side of the frame. One day install.
You could use the remaining $175 to $200 for other stuff.
Google replacement Chev C-10 fuel tanks or check LMC Truck
Hope this helps
Dan
Hope this helps
Dan
this will work fine to
15 Gallon 57 Litre Lightweight Polished Aluminium Fuel Cell w Sender | eBay
sparkyj
05-26-2012 08:20 AM
jdc48ford
02-10-2002 12:58 AM
