Help! Truck Down! 2011 Ecoboost
Old Dec 27, 2015 | 07:39 AM
Brandon150's Avatar
Brandon150
Yesterday I changed all 6 spark plugs for the second time on my 2011 F150 Ecoboost. The first time I changed them was around 70,000 miles and now I'm at 134,000 miles.
Anyway, when I started the truck the first 2 times after I finished last night it cranked 3x longer than normal, it idles fine, but barely runs down the road. The truck has very little power and feels like it's running on 2 cylinders.
Possible issues that I think could be causing this include:
- there's a wire harness over the one spark plug that got knocked around when I was removing the spark plug cable yesterday, I will get a picture in a bit
- issues with the new plugs? anyone know what the gap should be?
- I don't think I got the spark plug "wires" mixed up but I'm going to check again
thanks for your help
Old Dec 27, 2015 | 07:55 AM
sammy77's Avatar
sammy77
Did you use Motorcraft? SP534? Gap is .028 Did you replace the boots as well?
The good news is with a misfire, the CEL will come on, and give you a starting point.
Old Dec 27, 2015 | 10:46 AM
QwkTrip's Avatar
QwkTrip
Maybe you left the high-pressure fuel pump unplugged.
Old Dec 27, 2015 | 10:59 AM
Brandon150's Avatar
Brandon150
I think that's the plug I might have damaged. My engine light never started flashing which could mean I wasn't getting miss fires...? so maybe fuel wasn't being injected.
Old Dec 27, 2015 | 11:46 AM
GlueGuy's Avatar
GlueGuy
OBD codes? I know that I swapped a couple of wires one time, and that was adventure!
Old Dec 27, 2015 | 11:50 AM
Brandon150's Avatar
Brandon150
I don't have a code reader.
Old Dec 27, 2015 | 12:10 PM
QwkTrip's Avatar
QwkTrip
No matter what car I am working on, I do only one plug and wire at a time.
In this case the lay of the harness makes it really hard to screw up, and the fact it is coil on plug.
Old Dec 27, 2015 | 12:14 PM
Brandon150's Avatar
Brandon150
My dad walked over when I had all the plugs out yesterday and said the same thing "I always did one at a time".
Old Dec 27, 2015 | 12:42 PM
Brandon150's Avatar
Brandon150
So, since it cranks and takes so long to start should that be an indication that the fuel system is the issue? I'll post a picture as soon as I remember how to.
Old Dec 27, 2015 | 12:55 PM
QwkTrip's Avatar
QwkTrip
That was the logic I used with my guess.
There are two fuel pumps. The one in the tank is a lift pump, and that metal block on the passenger side cylinder head is the high pressure pump. Maybe enough fuel is provoded by the lift pump to start and idle (poorly) but not drive. I'm just guessing of course, as I don't know if that is possible.
Old Dec 27, 2015 | 02:39 PM
Brandon150's Avatar
Brandon150
You can see in the picture the brown and yellow wire I damaged during the plug change. Can anyone tell me what that wire does for the fuel pump and if that could be causing the problem? It looked like it wasn't pushed in far enough and we're working on it right now.
Old Dec 27, 2015 | 02:54 PM
Brandon150's Avatar
Brandon150
That was the problem, we got the wire back in there and the truck is running great. I use ford spark plugs CYFS12YT3.
Old Dec 31, 2015 | 04:58 PM
GlueGuy's Avatar
GlueGuy
That's a good plan. I did it when I was young & foolish, and I was replacing the entire spark plug wire set. Hopefully I am a little smarter these days...
Old Dec 31, 2015 | 06:48 PM
Tom's Avatar
Tom
Glad to hear you got it figured out!
Old Jan 2, 2016 | 08:27 AM
GuyGene's Avatar
GuyGene
Whew, I've been there. I also was once young and foolish. Well, the young part has long since gone...
daghstdrummer
May 24, 2019 09:26 PM
Montana_Rig
2004 - 2008 F150
Dec 11, 2015 12:38 PM
NW 150
13
Sep 3, 2010 09:19 AM
KevinAH
2004 - 2008 F150
May 4, 2010 04:12 PM
paulcalif
Jan 24, 2004 09:51 PM
