Complete lock set
I do not know about your local locksmiths but all the locksmiths around where I live will not touch re-pining the locks unless you provide all of the parts they need to do the job.
That includes the pins (wafers), nose cap and the wafer cap(if ignition).
I had change the combination myself for the Ignition to match the doors as my wife did not want to carry two keys for the truck. Took the wafers out of the old cylinder and put them in the new cylinder.
My door lock on my F250:
Back to the replacement locks.
Yes mine look like the ones in your photo! Gona check that place out next.
As I say, I'm not a locksmith but locks are interesting to me so like most anything I'll give it a shot. Nothing difficult about these except that darn cap. They make replacement caps that have 3 or 4 tabs on them that can be put back on MUCH easier than the original cap. I should have went with that instead of buying a tool and trying to use the original. Junkyard locks are a dime a dozen and you can build an assortment of wafers, procure the replacement caps and you're good to go. It's a matter of originality/challenge vs cost. I'm poor/cheap and love a challenge so "🎼 I did it my waaaaaaay.🎤"
It is pretty simple The link that subford posted earlier is the seller that has the OEM FORD parts for under $100
Here is another one of his listings. If you cant find Exactly what you are looking for, Contact him and he will help you out
http://www.ebay.com/itm/Ford-1992-95-F150-F250-Pick-Up-Ignition-Door-Lock-Cylinders-w-2-Keys-Black/151933913126?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140602152332%26meid%3D46f7bb548b974eefaf314da0e06e91e5%26pid%3D100011%26rk%3D5%26rkt%3D10%26sd%3D161927752133
This seems like a lot of trouble just to carry one less key on the key ring. The ignition lock cylinder takes all of 30 seconds to replace (as long you have a functional key) and the door locks may take an hour combined. I have had a couple Broncos and if memory serves me correctly even my '94 still needed the round key for the tailgate. You could have had them replaced by now but to each his own.
Received 3,159 Likes
on
#28
#29
#30
But the 92+ trucks only use ONE key for the doors, ignition, console and glovebox
