View Poll Results: Which engine do you perfer?
4.6L
0%
5.4L
0%
5.8L
85.71%
6.2L
14.29%
Voters: 7. You may not vote on this poll
Swap engines??
Old Aug 7, 2003 | 06:55 PM
FireHazard's Avatar
FireHazard
Swap engines??
I have a 99 F250 light duty with a 5.4l engine in and i here so much about these 460's would it be worth swapping the 5.4 for the 460?? and if i did what would be the benifits?
Old Aug 7, 2003 | 09:54 PM
pfogle's Avatar
pfogle
Swap engines??
You'll better off leaving the 5.4 in there. The 460 gets 8mpg loaded or unloaded, and makes less horsepower and torque.
Old Aug 7, 2003 | 10:38 PM
FTE Herman's Avatar
FTE Herman
Swap engines??
Amen brother. An not only loaded or unloaded but with the wind or into the wind or uphill or downhill.
Old Aug 7, 2003 | 11:11 PM
fishin1976's Avatar
fishin1976
Swap engines??
You will have lots of problems installing anything but the 5.4L, I voted 5.8L but only because I've heard of the problems that the 5.4L had iin early milage.
You must have alot of time and resources to repower a 99 with a different engine.
How do overcome the electronic trans and the OBDII computer? That , I think, will be your hardest challenge.
Good luck.
Old Aug 8, 2003 | 04:48 AM
pfogle's Avatar
pfogle
Swap engines??
It's probably still the 4r100 in a 99. So that wouldn't be hard. You would just need to do a completer computer/engine/tranny swap.
Old Aug 9, 2003 | 07:07 PM
FireHazard's Avatar
FireHazard
Swap engines??
him 5.8L eh i wonder how much one of thoses whould run me and what is the difference in horses in the 2 engines 5.4L-5.8L?
Old Aug 9, 2003 | 09:20 PM
ratstang's Avatar
ratstang
Swap engines??
What's a 6.2L? I've never haeard of that one.
Old Aug 10, 2003 | 02:44 PM
dozippy's Avatar
dozippy
Swap engines??
My van had a 460 in it, when it was running correct it got 8 mpg put it had some torque, my brother but a 4 bbl dbl. pumper and it flow off the line set you back in your seat till you hit about 45mph then it would let up, the only problem with it was I was getting 3 mpg. not good.
galaxie460
Modular V8 (4.6L, 5.4L)
Jun 30, 2014 03:03 PM
fordBigBlock
Dec 16, 2011 11:17 AM
joestang460
Jun 27, 2011 02:23 AM
E460
Engine Swaps
Nov 29, 2007 10:45 PM
Bigblock Ranger
Mar 5, 2004 10:22 PM
