1978 - 1996 Big Bronco
Cd player swap
Old Aug 7, 2003 | 06:43 PM
endroad_06's Avatar
endroad_06
Question Cd player swap
My 94 bronco came with an am/fm cassete stereo. I would like to remove that and put a cd player in it. i know a lot of people have do this.
How hard is it to install and can someone with limited experince do it?
Old Aug 7, 2003 | 10:21 PM
mweeps's Avatar
mweeps
Cd player swap
Not hard at all if you buy the correct wiring harness then it just is a straight replacement. Go to installdr.com for how to info.
Old Aug 8, 2003 | 08:57 AM
Crazyromi's Avatar
Crazyromi
Cd player swap
I put a new CD player in mine back in december. Also replaced all four speakers. It is pretty easy. I had never done it before and had no problems. I went through Crutchfield for all my stuff. They list what will fit your truck and provide all the wiring harnesses, and instructions that you need. I just crimped the wires plugged it in and went on my way. Check out www.crutchfield.com, go to the 'Create your vehicle page' link, enter all your info and they will give you a list of what fits.
Old Aug 8, 2003 | 01:55 PM
pezley69's Avatar
pezley69
Cd player swap
I agree...it is easy as pie. Pull out the factory stereo...find you a nice unit you like and pick up the wiring kit. It took me about 30 minutes to hook it all up and pop it in. The wiring harness had all the wires labeled and you just hook them up to the back of the new stereo and plug it into the existing truck harness. I think any decent size stereo store has the harnesses. I believe mine ran about ten bucks.
Hope this helps.
Old Aug 24, 2003 | 12:43 AM
94Bronco58's Avatar
94Bronco58
Cd player swap
I installed an Aiwa CDC-Z127 in my '94 myself, bought the unit off of E-bay, went to circuit city and bought harnesses, and took care of it in one day. Head Unit only cost $80 w\shipping on E-bay brand new.
Old Aug 24, 2003 | 01:14 AM
BroncoRoadKill's Avatar
BroncoRoadKill
Cd player swap
Hey 94Bronco58
How do those new Aiwas hold up to offroading? I am planing to get one as soon as I get some money to burn. My old JVC cd-player is worn out and won't hardly play a cd now, its like having the stock am-fm radio.
Old Aug 24, 2003 | 02:17 AM
oregonian's Avatar
oregonian
Cd player swap
I agree with ordering from crutchfield. They will usually include the wiring harness adapter that you need for your vehicle for free when you order your deck, at least thats what they did for the last stereo I ordered. Installation is a breeze with the correct adapter. Just unplug, plug, and thats it!
Old Aug 25, 2003 | 08:21 AM
BillyBob69's Avatar
BillyBob69
Cd player swap
When you go to remove your factory stereo, swing by a stereo shop like Car Toys, Best Buy ect, and see if they will do it for you. Usually one of the guys just runs out and slides it out a bit so you can do the rest. Only takes a few seconds and usually free. The factory head units need a special clip type tool to release the locks. They cant sell them to you but they can use them for you. Once those are used, the factory stereo will just slide right out. then unplug the wires from the back. Then while you are there...get a harness adapter for your truck. It will make the wiring go real easy. GOOD LUCK!
Old Aug 25, 2003 | 09:16 AM
Crazyromi's Avatar
Crazyromi
Cd player swap
when I bought my stereo those u shaped tools to remove the factory stereo came with it. I assume you can get them at any car stereo shop pretty cheap
Old Aug 25, 2003 | 09:25 AM
BillyBob69's Avatar
BillyBob69
Cd player swap
Well at least here in Colorado, the stereo shops are not allowed to sell them to you. But, if they have extra sets and they give you a set, then go for it!
Old Aug 25, 2003 | 09:36 AM
BroncoDave's Avatar
BroncoDave
Cd player swap
Actually it's much easier than all that. Just cut a couple pieces of coat hanger and bend them into a "U" shape, insert them in the "key holes" on each side of the Ford factory receiver to release the lock. For detailed instructions see the following link:
http://www.installdr.com/InstallDocs/FLM/PDF/356037.pdf
(credits to AlM's great Bronco Links web site!)
Good Luck!
Old Aug 25, 2003 | 09:53 AM
BillyBob69's Avatar
BillyBob69
Cd player swap
YOU GO DAVE!!!! OK Everyone lock your doors and keep an eye on your stereos.....Ya never know when Dave is gonna strike!
Old Aug 25, 2003 | 10:23 AM
BroncoDave's Avatar
BroncoDave
Cd player swap
Ahhhh Yess. The market for obselete, worn out Ford factory cassette players is booming. Better park your Ford in the garage too, just to be safe!!
Old Aug 25, 2003 | 10:25 AM
BillyBob69's Avatar
BillyBob69
Cd player swap
AHHHH HAAAAA!!!! So it was you that took it! hehe
Old Aug 25, 2003 | 09:18 PM
GypsyR's Avatar
GypsyR
Cd player swap
That's a funny law in Colorado. In South Carolina you can buy the U-tools in the stereo section of the local WalMart. Nothing works quite as well, but I have seen salvage yard guys use 4 pieces of cut up car antenna. "Limber" wire won't work as you have to apply a bit of outward pressure to pop the radio loose. Most radios come loose easily, but sometimes you have to really wrestle with one, even with the proper tools. Or maybe I'm just not holding my mouth right.
