Wheel bearing problems
Old Dec 24, 2015 | 10:25 AM
  #31
jhl3's Avatar
jhl3
Quoting Guzzle article:
"The bearing race on the hub axle will be damaged if the needle bearing were to run dry and would require replacement of the outer shaft.
99% of the Ford dealers will tell you that only the complete axle shaft and u-joint is available and will run about $500 per side. There is actually a Ford replacement outer shaft (4C3Z-3B387-AA} and it will run around $120 plus the cost of new needle bearing, inner and outer grease and dust seals for about $250 per side."
Link to best OEM price I can find:
http://parts.autonationfordwhitebear...ord/4c3z3b387a
Much better price here non-OE:
http://www.drivetrainamerica.com/sea...&Search=Search
Old Dec 24, 2015 | 04:03 PM
  #32
Kwikkordead's Avatar
Kwikkordead
I bought all my parts for the wheel bearings, axle shafts, etc. on ebay
Old Dec 24, 2015 | 04:07 PM
  #33
Kwikkordead
http://www.ebay.com/itm/370970442208?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/151231711336?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/350829023480?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.com/itm/360886789949?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Dec 24, 2015 | 04:29 PM
  #34
bielaf's Avatar
bielaf
I used Detroit axle bearings on my truck cause they cost less and I think it would have held up if I didn't have the problem I'm having now. They also have the option of buying two as a package deal and it cost the same amount as one of the cheaper ones from the local parts store. That might be the route I go when I buy mine just so I have an extra on hand since my passenger one i do believe is a Spicer one that I got from carquest and if it wasn't for my company discount it would have cost me in the 300 range
Old Dec 24, 2015 | 04:31 PM
  #35
bielaf's Avatar
bielaf
I wasn't able to do the zip tie today when I got off work it was snowing and I didn't feel like laying in the snow even though it would have be a short time I had to lay in it
Old Dec 26, 2015 | 04:01 PM
  #36
THEDON117's Avatar
THEDON117
Originally Posted by bielaf
No I had a really really bad vibration between 30-45 and after I did all the work it went away and a day later it was back but faint and that evening I was half way home from work and there it was back in full force again. The reason I replaced it was when I pulled the old one the bearing in the back all the small needle bearings fell out of it. I did apply a generous amount of grease to it before I installed it as well.
So this is exactly what I have been dealing with and you will see my posts about this too. Exactly what you mentioned in your comment is what I have. I replaced my p/s wheel hub assembly because when I took it off to grease it the needle bearings all fell out. The d/s looked fine. I did the same and checked the races of the stub shafts they looked fine and didn't look worn. I re-lubed both sides heavily. But I am still getting a vibration, that feels like the edge of the road ridges and sounds like a faint jake break. I too was wondering if it is a drive shaft issue, but I still am not sure. I will try locking the hubs and see if it stops or subsides.
All I know is I'm tired of replacing parts on the front end of this truck. It seems like that's all I do. It's starting to be a money pit and quite frankly I'm done doing that. I miss the days of not having to worry about that sort of thing.
Old Dec 26, 2015 | 04:05 PM
  #37
THEDON117's Avatar
THEDON117
Originally Posted by Kwikkordead
I just replaced both front wheel bearings, stub axles, u-joints, axle seals, all at once for the exact same symptom. Felt like a driveshaft was out of balance except the frequency of the vibration doesn't follow vehicle speed up and down. Been two weeks now and so far so good. Fingers crossed.
So how bad was it replacing the stub axles? I have done so many wheel hub assemblies I can do it with my eyes closed. So, I've been close to that stub, how much of a pain in the ars is it to pull those things? Do you or anyone have a step by step on removing/replacing those?
Old Dec 26, 2015 | 05:13 PM
  #38
Rikster-7700's Avatar
Rikster-7700
Really not that hard, you have already done the hard part getting the hub assemblies off. I just used a pry bar between the u-joint and knuckle and they pop right out. You will need to replace the knuckle seal (if you are changing the stub axle out), there are plenty of write ups on a hone made seal driver. Replace the stub and/or u-joints and they (axle) then slot back in and I use the hub assembly to seat the seal in the knuckle as I am tightening them back down
Old Dec 26, 2015 | 11:07 PM
  #39
THEDON117's Avatar
THEDON117
Sounds like some cussing will still take place lol. I'm hoping I won't have to do that but we shall see. I wish I had folks on this forum that are close by to hook up and see first hand what issue you are having. Or just to have someone help you out with some of the fixes. Anyway I'm going to try locking the hubs and see if it's still making the same noise or if it goes away, so I can narrow this down some more.
Old Dec 26, 2015 | 11:20 PM
  #40
bielaf's Avatar
bielaf
Yes if I spin my front drive shaft the wheel shaft spin with transfer not engaged in 4wd
Old Dec 27, 2015 | 07:44 AM
  #41
Kwikkordead
The axles pop right out with a pry bar. Nothing holding them in but the tension of the seal. The hard part is replacing the u-joints, the caps get very rusty. I used a ball joint press to do the heavy lifting.
Old Dec 27, 2015 | 10:13 AM
  #42
THEDON117's Avatar
THEDON117
I'm really hoping I don't have to change out the stub hubs. Tomorrow when I go to work I'm going to lock the hubs and see if the vibration goes away. I think I would rather change the carrier bearing instead of doing more work in the front end. I just wish I had another FTE member around to see exactly what I'm talking about lol.
Old Dec 27, 2015 | 11:02 AM
  #43
Kwikkordead
I went so far as to remove the rear drive shaft and then drive around on the front axle. Funny part about that experiment is that by doing so, all the vibration was eliminated and so by going on that result, I was really wondering what the issue was. Driving around on the front axle, never once produced any of the vibration that was experiencing before. The only reason that I did the front bearing, axles, etc. was I discovered that the stub axle bearing were toast due to age and exposure to the elements.
The way that it felt on my truck was very much like driveline vibration except that the frequency of the vibration didn't follow vehicle speed up and down, so I knew that I had to look elsewhere for the source of the problem. Lifting the truck so the wheels dangled and then spinning, prying back and forth didn't reveal anything. Had to drive it and hit potholes, grooves in the pavement, irregularities in the road surface and the vibration would turn on and off like a switch.
Drove me nuts.
I never could put my finger on it while the truck was off the floor in the shop.
Old Dec 27, 2015 | 11:06 AM
  #44
Kwikkordead
And now I've had a chance to drive around for a while on the new bearings, u-joints, stub axles, and the vibration hasn't even tried to show it's face.
Old Dec 27, 2015 | 12:56 PM
  #45
THEDON117's Avatar
THEDON117
Drove me nuts.
That's pretty crazy. It's not a bad idea driving around without the rear drive shaft. I know the feeling, it's driving me nuts changing out parts and still having issues with vibration. Did you ever do your carrier bearing? I've already done wheel hub assemblies, ball joints, and sway bar bushings. I haven't done the u joints. My rear drive shaft does have new u joints but it has the original carrier bearing. I can honestly say I'm tired of Changing parts on this beast. I have to plan when it's time to wrench because of work, family and funds.
