Inexpensive windshield washer mod.
Old Dec 23, 2015 | 11:39 AM
superrangerman2002's Avatar
superrangerman2002
This is a little something I do to my vehicles when I buy them.... Just finnally got around to it on my psd.
Duration: 1 beer (or longer if you desire).
Items needed:
2 3/16" vacuum / washer hose splices
Approximately 15' of 3/16" id washer hose.
Zip ties.
Procedure:
1. Cut ww line near the cap but 1 or 2 inches on the really flexible part of the existing ww hose.
2. Using a splice, splice the line with the new hose and lay across cowling as shown. Lay line to near oil dip sticks.
3. Gently remove existing ww hood connections and flip the hose setup so that the hose supply line is now on the drivers side. The hose holder canbe slid up to use a different hood hole as shown.
4. Using care and patience, wrap about 10' of your ww line around the top radiator hose for the engine without kinking or pinching the line. Wrap it tightly but not so tight that the hose id collapses...gently zip tie both ends to keep the coil snug against the hose. Try to locate ww hose such that it will not cause rubbing.
5. Using a splice, hook up washer nozzles. Try to leave enough lead so that the hose doesn't hook something when opening the hood.
Congrats you now have an inexpensive heated windshield wash system.
Estimated cost: less than $15.
Old Dec 23, 2015 | 11:49 AM
SavageNFS's Avatar
SavageNFS
Thanks for sharing this idea!
Old Dec 23, 2015 | 12:11 PM
superrangerman2002
It works great for bugs in summer too.
It sure makes driving in the winter conditions that ice up the wipers and such a non issue.
The only draw back is that it only works when the engine is warm.
Old Dec 23, 2015 | 12:15 PM
darren32's Avatar
darren32
That is great, thanks!
Old Dec 23, 2015 | 01:00 PM
djousma's Avatar
djousma
Excellent idea!
Old Dec 23, 2015 | 02:43 PM
jonrjen's Avatar
jonrjen
You need to print off these directions, then box up the needed parts. Buying in bulk it should cost you about $4 per kit to do so. Then start selling these on an infomercial on late night TV. You could sell them for $49.95 each. But wait, there's more. If they order in the next 30 minutes you will double the order (just pay separate shipping and handling). Of course the separate S/H would be $17.95.
Old Dec 23, 2015 | 03:34 PM
Rutcutter's Avatar
Rutcutter
Great idea,gonna do this mod myself..
Old Dec 23, 2015 | 03:40 PM
FishOnOne's Avatar
FishOnOne
Reps sent......
Old Dec 23, 2015 | 03:57 PM
Hopeless Diamond's Avatar
Hopeless Diamond
Good idea. I have to change out a washer head anyway, it broke right at the hose connection. Anybody else ever had this happen? The parts guy said it's pretty common, he sells the washer nozzles all the time to county maintenance department, their trucks are always breaking them for some reason.
Old Dec 23, 2015 | 04:00 PM
SavageNFS's Avatar
SavageNFS
My 2011 did that as well...
Old Dec 23, 2015 | 04:32 PM
Iowa Ford's Avatar
Iowa Ford
Great idea, thanks for sharing it with us !
Old Dec 23, 2015 | 04:58 PM
bayou barataria's Avatar
bayou barataria
I agree, super idea. I bet you could run some small copper line in loops down by the exhaust somewhere and it would work better in the wintertime.
Old Dec 23, 2015 | 06:59 PM
superrangerman2002
I should mention that it doesn't hurt to go a bit bigger in hose id to account for pressure drop. I don't think it's a big deal however.
Also there will be a delay in spray at times as the fluid will cook off over time.
Old Dec 23, 2015 | 07:06 PM
superrangerman2002
That would work too. I prefer the hose method as it doesn't burn off the water so fast.
Old Dec 23, 2015 | 07:08 PM
superrangerman2002
Mine too. Have a spare on hand.
