Sponsored by: Real Truck
Any weight for winter?
Old Dec 21, 2015 | 05:15 PM
xr7gt390's Avatar
xr7gt390
I never put extra weight in my F150's for winter and got along just fine. I live just outside the snow belt in NW Indiana. We do get a couple of heavy snows and a bunch of minor ones. We had a wet heavy snow a couple weeks ago & it seemed like the F250 might benefit from some extra weight. How much do you put in? Does it do anything?
Old Dec 21, 2015 | 05:23 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
For my climate the typical is 400-600lb in the back, sure seems to keep the rear of any pickup more planted.
Old Dec 21, 2015 | 05:25 PM
Just Strokin's Avatar
Just Strokin
I would add some buckets of sand maybe....but I never had any troubles with my old 96 F350 with single traction
Old Dec 21, 2015 | 06:27 PM
seville009's Avatar
seville009
I put five 80lb tube sand bags in my Excursion. In my crew cab that I pliw with, I carry ten sand tube bags plus a bunch of junk. The weight definitely helps, along with snow tires.
Old Dec 21, 2015 | 07:00 PM
Chuck's First Ford's Avatar
Chuck's First Ford
my 250 had 2,600 pounds on the rear empty.. and 3,400 on the fronts.. so YES...
I started doing this since my 1972 Kingswood wagon.... under the rear floor..... back in the mid 70's... rear wheel drive loves added weight for Snow driving.
old bar bell weights and bags of sand..
<<< mine is 2 wheel drive >>> no need for weight if 4x4... that is why 4x4 was made.
Old Dec 21, 2015 | 08:21 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I used to add weight to my Ranger, but never bothered with the 250 while I lived in Colorado, or in Lubbock (where it does actually snow some years).
I'm 4800 FGAW 3500 RGAW, just never really needed it. But Denver is not really a mountain town, snow isn't really that bad or frequent most years. Big dumpers that keep you in and light dustings that don't count, but not a lot of solid 6" snow days that make you have to get out and slog through the mess, and it doesn't ever hang around long.
On snow the tires make a bigger difference, just lock the trans in 3 and start slow. On ice I'm not sure I want to be able to go any faster that what I can start at without extra weight because then stopping becomes the main problem. That was what sucked in Lubbock, essentially no plows so the roads turned to skating rinks. Not like CO where with sun and 15*f the pavement dries up within a day.
Old Dec 21, 2015 | 08:22 PM
Bugzilla46310's Avatar
Bugzilla46310
No xtra weight
I live in DeMotte. I have never put extra weight in my 250 sb, cc. In fact, I keep the hubs locked in all winter, but rarely lock in the transfer case. Most of my driving is on I65. I do have a fiberglass cap on the 6.5 foot bed. Thanks. Joe
Old Dec 21, 2015 | 08:38 PM
senix's Avatar
senix
I just lock the hubs in manually and engage the fronts if needed. I don't carry anything extra.
Old Dec 21, 2015 | 09:05 PM
moymurfs's Avatar
moymurfs
I would just fill the bed with snow that I shoveled from around the driveway/walkway areas. It magically reduces itself and empties when the snow starts to melt.
Old Dec 21, 2015 | 09:28 PM
Platinum08's Avatar
Platinum08
I use 6-8 bags of tube sand behind the rear axle. Never have to lock it in to 4x4 unless I was pulling someone out of the ditch and that was only cause I didn't want screw around...
Old Dec 22, 2015 | 08:53 AM
phillips91's Avatar
phillips91
With my first truck, an 86 Mazda b2000 that was 2wd, I kept some weight in the bed in winter. With my super duty I've never had to put anything in the bed, but it's 4wd.
Old Dec 22, 2015 | 09:03 AM
redford's Avatar
redford
FTE Leadership Emeritus
This is what I do also. Besides weight, the sand can be used for other purposes.
In a pinch, if you hit bad ice, a handful of sand tossed under the tires and along the path will get you going and the people stuck in front of you.
In the spring, the sand is used to fill pot holes in the driveway.
Old Dec 22, 2015 | 09:14 AM
shadetreezj12's Avatar
shadetreezj12
Fat chicks.
Old Dec 22, 2015 | 11:22 AM
Good listener's Avatar
Good listener
In my F-150 I used 3 iron stage counterweights that weighed 50lbs each over the rear axle. they didn't take up much space and were easy to handle. The F-250 weighs more, and does pretty well in snow when empty.
Old Dec 22, 2015 | 11:37 AM
NotURMailman's Avatar
NotURMailman
When I lived in snow country I would throw an old no good short block from a 350 in the back of my 2wd F150 during snow season. But, I wouldn't think most people would have one of those just laying around.
