stall after starting
Old Aug 7, 2003 | 04:21 PM
19903024x4's Avatar
19903024x4
Question stall after starting
after my truck has been sitting for a while.....like overnight or after work in the evening after i start it it will die 3 or 4 times before it will keep running.......when i start it the 1st time if i gas it and keep the rpm's up for a little bit then take my foot off the gas it'll stay running.......its recently got a complete tune up and oil change......the truck has 150,000 miles on it......or should i be happy this is the only thing wrong?
Old Aug 8, 2003 | 09:02 AM
2johns's Avatar
2johns
it might be a cracked distributer cap,is it hard to start when it is real wet out ,if it is its your cap forsure
Old Aug 8, 2003 | 02:07 PM
19903024x4's Avatar
19903024x4
its had a tuneup so thats all been replaced
Old Aug 10, 2003 | 09:53 PM
steve83's Avatar
steve83
Pull the codes and test the IAC according to the Haynes manual procedure. That thread has a link to the full code list, and you can get a Haynes at most parts stores for ~$12. You'll also need a multimeter, and Radio Shack & Sears sell them for $10-300. The $10 version will work, but I recommend spending ~$40 for a decent one.
Old Aug 10, 2003 | 09:58 PM
19903024x4's Avatar
19903024x4
i'v got a ford code reder.......i'll give that a shot and see what happens......thanks
Old Aug 10, 2003 | 10:42 PM
steve83's Avatar
steve83
You don't need a code reader for your truck's computer. Read the thread I linked, or the instructions in the Haynes manual. If you put a jumper wire (paperclip) between the 2 connectors, the ENGINE light will flash out the codes just like your "code reader". It's just a black box with an expensive connector, a switch & a light. There's nothing inside it. You're paying for the book that came with it, and that thread has a link to my full code list which most people find to be better than the one that comes with the code readers.
You can certainly use the code reader, but it's not worth it IMO.
triton02
1983 - 2012 Ranger & B-Series
Jan 15, 2013 10:13 PM
4601ton
Jun 18, 2011 10:53 AM
tkerkela
May 4, 2010 10:51 AM
Hmann
Mar 9, 2010 09:23 PM
