Sponsored by: Real Truck
Rough idle
Old Dec 20, 2015 | 09:22 PM
Seth95's Avatar
Seth95
Rough idle
Hi everyone! I bought a 1999 f350 v10 about a month ago took it on a 1200 mile trip from Arizona to Kansas. Truck ran great till I got Kansas. The truck started to lope after I got fuel at a fuel station. Did not get any check engine light on. I check for vacuum leaks did not find any. I change all the coil packs, spark plugs, IAC valve and fuel filter. Clean the intake and put sea foam in the fuel tank and the truck still idles rough. Change the egr vavle. Truck ran great till I got 10 miles down the road then the truck started to lope again. So I'm getting really frustrated over this truck and looking for some help!
Old Dec 20, 2015 | 10:07 PM
Thor'sHammer's Avatar
Thor'sHammer
You didn't wash the top of the engine by chance did you?
Old Dec 20, 2015 | 10:16 PM
davester250's Avatar
davester250
maybe crappy fuel? might have semi-plugged the fuel filter?
Old Dec 20, 2015 | 10:19 PM
Seth95's Avatar
Seth95
No but when I was driving I traveled through a brunch of rainstorms for long periods of time. Is there another fuel filter located some where else on the truck?
Old Dec 23, 2015 | 12:49 AM
Thor'sHammer
No, if the top of the engine gets wet, it can sometimes cause havoc with the high tension side of the ignition system.
Grannygear
Oct 30, 2018 03:54 PM
rcamsler
Modular V10 (6.8l)
Jul 19, 2010 03:38 PM
paddler
Apr 6, 2009 03:04 PM
fordjeeps
Mar 10, 2004 11:02 AM
knucklehead11
Bronco II
Jul 22, 2003 12:56 PM
