'96 F-150 Steering problems
Old Aug 7, 2003 | 04:02 PM
southy7's Avatar
southy7
My truck has been hard to steer for awhile now....kind of squeaks when I turn the wheel too...what could be the problem?
Thanks!
Karyn
Old Aug 7, 2003 | 05:11 PM
90f150moneypit's Avatar
90f150moneypit
Sounds like it just needs a lube??
Old Aug 7, 2003 | 10:06 PM
MustangGT221's Avatar
MustangGT221
Check the fluid level in hte power steering pump.
Old Aug 8, 2003 | 10:19 AM
southy7's Avatar
southy7
Thanks for both of the responses....I will try that!
Karyn
Old Aug 13, 2003 | 12:58 PM
southy7's Avatar
southy7
The truck has had a lube job...and the power steering fluid is fine.....now what should I check?...it is still hard to steer
Thanks!
Karyn
Old Aug 13, 2003 | 01:17 PM
90f150moneypit
Does it require high effort or is it 'loose'?
Does it wander, is it just too hard to turn a corner or does it vibrate?
How is it going over bumps?
Old Aug 13, 2003 | 01:40 PM
southy7's Avatar
southy7
It requires semi-high effort to to steer...turn the corner....and I haven't noticed any problems going over bumps or it vibrating
Karyn
Old Aug 16, 2003 | 11:40 AM
steve83's Avatar
steve83
Have an alignment shop check it out. Most of them do free inspections.
