not running
Old Dec 20, 2015 | 08:47 PM
oldbird1965's Avatar
oldbird1965
Post 294, some bed time reading:
https://www.ford-trucks.com/forums/1...inally-20.html
Old Dec 22, 2015 | 07:03 PM
therigwelder's Avatar
therigwelder
Well thanks for the help,looks like I am in the market for another motor
Old Dec 22, 2015 | 07:46 PM
oldbird1965
compression not good?
Old Dec 22, 2015 | 08:54 PM
therigwelder
Not entirely sure. I have to braze an adapter together for my compression gauge to make it official.when I pull a glow plug and crank it over I can hear compression but it sounds low.
Old Dec 23, 2015 | 03:22 PM
therigwelder
Anyone got a short or long block or an entire engine for sale?
Old Dec 23, 2015 | 08:32 PM
fordpride's Avatar
fordpride
What was the compression numbers ?
Low compression can be caused from bent valve and broken valve springs which can happen with the use of starting fluid.
Look over the springs real good then pull the push rods and lay a straight edge across the valve and see if any sit lower than the others. It's a long shot but I'd check al possibilities before I'd start looking for a engine. If I was at that point I'd do a rebuild that way you know what you have. A used engine is like play roulette.
Old Dec 23, 2015 | 08:43 PM
ReBilld's Avatar
ReBilld
Whatever you use for an adapter has to have a very small hole through it. I tried using a 6" long piece of 1/8" brass pipe, but the hole through the pipe was too big......too much volume. Made one with a grease hose like most on here have. there was a 100 psi loss with the brass pipe vs the grease hose.
Old Dec 25, 2015 | 05:32 PM
therigwelder
the compressions were between 140-150 psi. I made an adapter for my pressure gauge out of an old glow plug and a 12" piece of 3/16 brake tube so I don't know how accurate it is
Old Dec 25, 2015 | 08:55 PM
ReBilld's Avatar
ReBilld
That is pretty low, but with the experience I had with my homemade adapter, I would wonder how much of those low numbers you could contribute to you adapter. I ordered a brass fitting that was male M10 to female 1/8" pipe. I bought the shortest grease whip I could find at the auto parts store and screwed it into the female end of the fitting. I put an 1/8" brass pipe coupling on the other end of the grease whip, then screwed the quick connect fitting from my compression test kit into the coupling. That seems to work really well because the hole in the grease whip is very small. Smaller than 3/16" I believe. I would try to make up one like this before I would be satisfied with those numbers.
Old Dec 25, 2015 | 10:46 PM
therigwelder
I have 295k on the motor and has a repaired hole in the block and I've been driving it a few years.obviously I won't rebuild this block.what puzzles me how when it was running it didn't smoke ,ran like a champ. I am stuck on the idea the cylinder walls got washed out using SF thereby losing compression,I know in gas engines I've had the oil on the cylinder walls filled in scratches and hatch patterns and contribute to the sealing of the cylinder.
I have an idea of liberaly spraying Wd-40 into the glow plug holes then spin the motor over getting the cylinder wall lubricated(wet test). I think if I can get compression over 200 I might be able to get it to fire.
Also when I pulled the glow plugs they were coated with a lot of oil. Is this oil coming from around the top of the glow plugs? I don't believe there should be oil down around where the hot end of the glow plugs seats ?
deerdog
Mar 16, 2015 07:49 PM
marauderx
Jan 7, 2013 09:09 PM
diamondjranch
Jun 15, 2012 06:29 AM
flatbedstroker
16
Mar 3, 2009 11:25 AM
Fourwheelinj1
Oct 22, 2007 09:51 PM
