6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cyl 2 Misfire, But Engine Smooths When Code is Cleared
Old Dec 19, 2015 | 04:14 PM
Rich S's Avatar
Rich S
I'm trying to help a friend with his 2008 F250 6.4 Powerstroke. It has an intermittent misfire. The day we started it, it ran smooth for the first few minutes, then it started to clatter and smoke badly and the CEL came on. We hooked up the autoenginuity and it showed a cylinder 2 misfire. When we cleared the code the engine smoothed out, quieted down and the smoke stopped. After a few more minutes, the same thing happened and again, clearing the code smoothed it out. I don't know what's causing the misfire, I assume a bad injector. But, is it normal for a code to cause the engine to run badly and for clearing it to make it run better?
Thanks,
Rich
Old Dec 23, 2015 | 07:47 PM
speakerfritz's Avatar
speakerfritz
how many miles...becareful with bad injectors...a run away injector could melt a piston....I would send the friend to a ford dealership and have the truck towed there.....your going to look pretty bad if as a result of clear the codes and driving the truck...he melts a piston...respectfully submitted for consideration.
Old Dec 23, 2015 | 08:35 PM
Rich S's Avatar
Rich S
200,000. He already took it to the Ford dealer because it was intermittently missing and smoking. They said it was a cracked piston and they pulled the head. There was some cylinder wear, but of course, there was no cracked piston. Not sure why they would think an intermittent miss would be a cracked piston??? Didn't stop them from charging $1500. So instead of paying another $2500 for them to put it back together, I did it for him. I don't think he's interested in another expensive misdiagnosis.
Achen
6.7L Power Stroke Diesel
22
Jun 9, 2019 06:36 PM
handifletch
Modular V10 (6.8l)
Jul 18, 2017 08:02 AM
Damien05
May 1, 2015 04:58 AM
Andrew7dg
1997 - 2003 F150
Dec 4, 2013 08:30 AM
GBURKS
Nov 23, 2010 10:14 PM
