2004 Excursion rear sway bar question
I know Hellwig is top shelf and there are others, I am sure but there has been a lot of maintenance and bringing it back to specs the three months I have owned it -- Hellwig is not on the radar screen. I will do the V and B mod upgrades in the spring. For now, I just want to remove a bar and the bushings and replace with a heavier bar and bushings -- same end links would be real nice. The tech folder didn't real help answer this question, I looked.
Thanks in advance for any help.
Doug
I am certain that there is a reasonably simple answer but before I go to the pull and pay or where ever to get a bar that it is correct I really want to feel confident about what I need. Read a lot, learned a lot, couldn't be sure of what I needed. With as much skill and brains as there is on this site...
So, if this is the way it goes, then it goes.
I appreciate all who did read it.
Thank you,
Doug
thank you for the response. Since I have done no mods other than Bilstein shocks, the sway bar is my next affordable upgrade. Hellwig, not so much ($$$). I was reading something in the tech folder about springs about an hour ago and there is a single bullet point that says "The 30 mm swaybar off of a Super Duty is much better than the stock ones if your Excursion came with one." That was authored by Stewart H. I am perhaps leaping to conclusions but an F350 rear sway bar sounds like a bolt-in replacement for the stock Excursion one -- except for the frame bushings, of course.
Just a quick question -- I had a professor once whose first name is Dean {McBride}(when he was Dean of Students he was Dean Dean). Anyhow, any relation?
Thanks,
Doug
Thanks,
Doug
You did find most of your answer.. I don't know EXcactly but the stock bar is like 27MM the F-350 is 30MM. Are U going to tell a world of diff, no But for the X's (like mine ) that don't have a bar at all, Well, Yes big diff. Almost anyone going for the f-350 bar is getting it in the salvage yard SO go get the biggest you can that crosses & pops right in. Are the links the same ?? don't know, you get the links with the bar SO if they are , Great, if there not, well you have the ones it came with. My brothers name id Dean...No relation
My EX didn't have a factory bar, I was towing a 9500lb toyhauler with the stock Ex suspension and the addition of a rear Hellwig was a huge improvement to that situation. It really helped but didn't make it "good enough" so I moved ahead with an X/B (modded) spring swap which made towing that trailer and the new heavier one so much better.
Otherwise, I will just swap out the springs and see how that improves things. It sounds like I may get all that I need from the spring swap anyhow.
The other difference I saw was that the truck links are longer, due to the taller springs. It's a couple inches difference, so with the modified B springs they are perfect. Not sure how much it'll affect the geometry if the ends of the swaybar are not exactly parallel to the ground, but mine ended up looking perfect, and works great! Best $25 bucks I ever spent.
Thanks for the response. The longer links OEM is understandable. Mine came with significantly longer links that I just swapped for the correct MOOG links. The ones I took off were in great shape -- so if I can find an F350 sway bar I can use it as is. When I get the mod B's on it, Ill just switch back to the longer ones I took off. Cool!
Turfzilla; Great link -- told me everything I needed to know. I sometimes have trouble when I do searches because I don't word it right or something. That link was what I was looking for.
Thanks all.
Doug
Thanks all.
Doug
It's not just you Doug, I have a hell of a time with searches for over 2 Years. The ticket is to book mark all the threads of interest WHEN you find them.
