engine compartment heat
Old Dec 18, 2015 | 12:50 PM
jniolon's Avatar
jniolon
old and in the way
can anyone give me an estimate or even a CWAG guess what the temperature under the hood of a '50's f-100 with a big block, headers, air conditioning, etc might be in the summertime... in the South or maybe West...
I'm figuring 300° or better... anyone ?? anyone ???
this is a serious question...really
j
Old Dec 18, 2015 | 01:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I don't think it's as bad as that. Depends where you are measuring. You have a lot of air coming thru the radiator at ~220 or less. It's going to sweep across the engine and out past the exhaust, carrying a lot of heat with it.
Old Dec 18, 2015 | 01:02 PM
Tedster9's Avatar
Tedster9
I dunno about 300, but it's going to push 200 easy. Here's a temperature compensation chart for voltage regulator adjustment as an example. They didn't have AC, but gives you some ballpark to work with. Hot day + Hot engine = pretty frickin' Hot !!
Old Dec 18, 2015 | 01:05 PM
jniolon's Avatar
jniolon
old and in the way
reason I'm asking... looking at some alternative coatings over the inside of the flip front... instead of filler and primer... found a product... a UV cured resin that is used on surfboards....
I need to talk intelligently to the vendor about air flow and under hood temps for him to recommend a compatible product... they have several that MIGHT work and wanting to find the best application... if this works like advertised it would do away with a lot of the grunt work and give a nice smooth paintable finish... at least with less work...
j
Old Dec 18, 2015 | 01:09 PM
fatfenders's Avatar
fatfenders
I am going to measure this summer. When sitting still and running, anything I have ever owned with long tubes gets stupid hot under hood during summer. Nowhere near 300 at the hood though. That is way past boiling water.
Old Dec 18, 2015 | 01:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'd say parking after a good run on a hot day, you'll get heat soak that will put the compartment closer to 300. Might be worth running your radiator fan after shutdown like modern cars.
Old Dec 18, 2015 | 04:25 PM
1950FordF1's Avatar
1950FordF1
I had not heard the term "heat soak" that Ross used. I looked it up and thought I'd share an article in case someone else out there hadn't heard either.
Thanks!
http://cjbfire.com/Heatsoak.pdf
robert_l_ross
Jul 22, 2017 05:02 PM
PAJARONEGRO
Sep 5, 2015 08:14 PM
Boaterguy
6.7L Power Stroke Diesel
Jul 15, 2015 10:11 AM
70blue
Georgia Chapter
Aug 13, 2007 06:43 AM
exiled
Nov 10, 2006 02:52 PM
