Back hatch issues
Old Dec 18, 2015 | 08:20 AM
RDockery's Avatar
RDockery
Back hatch issues
My back hatch or lift gate door won't open, but the glass window hatch does. Any suggestions on what the problem is and the repair?
Old Dec 18, 2015 | 10:30 AM
alloro's Avatar
alloro
There is a release cable inside the door that tends to break. You have to climb inside and remove the plastic panel in order to get into the hatch and access it.
Old Dec 19, 2015 | 06:07 AM
broncoholic's Avatar
broncoholic
Wow! Same thing happened to my wife's on Thursday.
Any suggestions on how to do this on an 03? It looks like the hatch needs to be open to remove the plastic panel.
Old Dec 19, 2015 | 08:51 AM
alloro's Avatar
alloro
It doesn't have to be open.
Old Dec 19, 2015 | 08:53 AM
alloro's Avatar
alloro
Here is a video showing you how to get into the rear hatch.
Old Dec 19, 2015 | 06:33 PM
broncoholic
Well, that's not an 03, but I'll give it a shot. Maybe tomorrow. Thank you for the video.
Old Dec 20, 2015 | 09:31 PM
broncoholic
Got the inside panel off and found the broken cable. $35 from my local Ford dealer, just wish they were open on Sundays. Easy fix, it'll take me longer to go pick up the part tomorrow than replace it.
Old Dec 21, 2015 | 04:25 PM
alloro's Avatar
alloro
Just for the benefit of others, did the procedure in the video also apply to your 2003?
Old Dec 21, 2015 | 09:22 PM
broncoholic
Ehh, not really. I'll call it similar, but overall many of the details were different. With that said, I had the broken cable out in 5 minutes. In addition to the 2 screws holding on the pull strap, the 2003 also has 2 plastic button screws where the window latch is that have to be removed. I removed the upper trim from around the inside of the window. I think that made it easier to pull the big panel and put it back on. The latch is different. With the panel off, it's easy to see the lever the cable attaches to and you can easily release the latch with your finger. The video shows plastic pieces that break on the cable assembly. The 2003 doesn't have the same plastic pieces. The inner steel cable broke on mine requiring a whole new cable assembly.
yardbird
61
Jun 25, 2021 10:50 PM
dcara
39
Jul 19, 2019 04:38 AM
kupaa
Oct 19, 2010 03:05 AM
Higgin
1983 - 2012 Ranger & B-Series
Feb 28, 2005 08:00 PM
alpine
Mar 24, 2003 05:34 PM
