Help with 4.6 question
Old Dec 18, 2015 | 05:05 AM
03excab's Avatar
03excab
I have a 03 that needs and engine and there is a local add for a F150 2007 4.6 90K for 800. Is it the same? Did they have the two piece spark plugs then? Does 800 sound good? Thanks
Old Dec 18, 2015 | 01:35 PM
davester250's Avatar
davester250
$800 for an '07 F150 with 90K sounds pretty cheap. You have to figure out why it's that cheap, if it's because the body is dented up and rusting, or because the engine isn't working right. I would suggest taking a code reader with you and seeing if it has any codes after a short drive (some people will clear the codes to make the vehicle seem better), besides checking how engine oil and transmission fluid look/smell .
I don't know if it's the same design motor for an easy transplant.
Old Dec 19, 2015 | 05:36 AM
03excab's Avatar
03excab
The add is only for the motor. I was just stating it was from a 150
Old Dec 22, 2015 | 09:01 AM
03excab's Avatar
03excab
Nobody knows???? I though there was a different reluctor wheel or something under the timing cover that made it more than just a swap???
Thanks
Old Dec 27, 2015 | 07:05 AM
03excab's Avatar
03excab
OK different question. Anyone ever do just a refresh? Assuming I find only minimal damage. What usually locks them up? LOL
outracn
Engine Swaps
Mar 16, 2026 06:25 PM
BadBee
Dec 15, 2015 04:10 PM
brcrk
Dec 1, 2014 04:40 PM
F 150 Tinman
1997 - 2003 F150
Sep 20, 2014 01:00 PM
Travis T
1997 - 2003 F150
Mar 23, 2007 05:06 PM
