You have read my thread and figured out what all I'm doing with the power distribution box? Or, much better yet, read the page on my web site: Power Distribution - Gary's Garagemahal
I did read your thread, and I believe I understand your plan. While I'm at work all weekend, I don't have access to your website, but will definately do so once I'm back home.
(Also, thank you for doing so much legwork to get that going!)
Originally Posted by Rusty_S
I got a box off ebay from a mazda/ford escape to use for my upgrades but after gutting the small box was just too heavy for my tastes so i found a aftermarket universal one that has four relays and eight fuses. The megafuse for my 3g upgrade will be a stand alone box mounted to the aide of this universal box.
I have purchased the exact same PD box as Gary, so I'll be installing the box and getting the megafuse when I do the 3G upgrade.
The way I figure, it's better to be a great copier than a bad inventor!
We will see how far I get with the electrical projects, I do have a list of parts I already purchased that need to go on the truck. I still need to get the 3G supplies.
Nothing wrong with copying. To be honest theres nothing original under the sun.
I personally like the idea of having the integrated mega fuse as it powers the box as well as protect the charge wire. Its just that everything is way too big for what I would need it for which is simply just for my lighting. Everything from park lights to brake lights to turn signals down to everything in the cab will use oem wiring.
Now if you are rewiring the whole truck then you wouldn't have a problem locating a box to fit your needs.
