Squishy Brakes
Old Dec 16, 2015 | 12:47 PM
Hammer77's Avatar
Hammer77
Squishy Brakes
Hello Everyone. I've checked out some places on the forum but can't seem to find what I'm looking for. I've got a 1985 F-250 with the 351Windsor.
I'm having a problem with my brake pedal sinking to the floor when I brake at anything over 10-15 mph (around town they work fine). I've replaced one of the rear wheel cylinders and it looks to be that the previous owner replaced the other side not too long ago. I've also bled the system a couple of times. (NOTE: I have only bled the rear because I can't seem to loosen the bleeders! Ugh!)
Can anyone help me?!!
Old Dec 16, 2015 | 01:19 PM
Galendor's Avatar
Galendor
I would try doing everything necessary to also bleed the front. Soak the bleeder screws in a penetrating solvent overnight.
You may have to put the front up on jacks and remove the front wheels to get good access to the front bleeder screws.
If they are really stuck, I have even had to use large vise-grip pliers to remove the bleeder screw. This will ruin it, but you should replace them with new ones anyways. Wrap the new replacement bleeder screw threads with teflon tape when installing, to help prevent the new ones from being stuck in the future.
Welcome to the forum!
66f100restoration
May 18, 2019 01:31 AM
rgnprof
15
Jul 13, 2016 07:26 PM
Broncoman1989
May 17, 2011 08:34 PM
dougf2504x4
Mar 1, 2009 12:43 PM
walkman
1983 - 2012 Ranger & B-Series
Jan 14, 2009 06:36 AM
