Glove Box Door Stuck
Old Dec 15, 2015 | 11:56 PM
UnknownCubicle's Avatar
UnknownCubicle
Hey, guys,
I tried the search bar, but couldn't find any other threads with the same issue addressed. Anyway, I finally got all the required paperwork done to get my truck on the road! I went to put the stuff in the glove box, which I have never opened, and lo and behold, the darn thing is stuck shut. The button won't go in or out and I kind of want to avoid cutting the cardboard box up to get at the latch from the inside if I can.
It's not the lockable sort, if that helps. Any wisdom would be appreciated.
Old Dec 16, 2015 | 12:27 AM
Cracker289's Avatar
Cracker289
Mine sometimes gets stuck because its not aligned very well, yours definitely a different issue (since the button is stuck). My advise is to coax the button to work using some WD-40 or similar.
Old Dec 16, 2015 | 02:28 AM
UnknownCubicle
That's not a bad idea. I'll try it tomorrow.
Old Dec 16, 2015 | 09:33 AM
MIKES 68 F100's Avatar
MIKES 68 F100
MY glove box button worked fine but door wouldn't pop open , I bent the upper striker (mounted to dash) down with a flat blade screwdriver . This fixed the problem for me . over time it must have flattened out .
Old Dec 16, 2015 | 10:52 AM
Coastal68's Avatar
Coastal68
Mine was pretty stiff when I got it. Try a little grease on the moving parts one you get it open. I did and it's like butter now.
Old Dec 16, 2015 | 08:44 PM
D & D's Avatar
D & D
My button wouldn't move very much at first. The door was slightly bent out and put a lot of pressure on the latch. I had to push the center of the door in and then push hard on the button. Slightly flexed the ends out to straighten it, some steel wool to the mating surfaces and proper alignment and now it's smooth as a baby's bottom.
Old Dec 18, 2015 | 05:25 PM
351Cleveland C4's Avatar
351Cleveland C4
There is a special tool that has been around for a long time for just these kind of stuck issuers....
HAMMER TIME!
Old Dec 20, 2015 | 08:56 AM
yetiman38237's Avatar
yetiman38237
Trying to keep my mind out of the gutter.....lol! Sorry!!
Old Dec 21, 2015 | 12:46 PM
wrhinehart's Avatar
wrhinehart
Me thinking.
Why worry about the box if the door won't even open?
LMC truck sells replacement boxes. I know...It's on my list. 15 bucks
Old Dec 22, 2015 | 04:26 PM
qman's Avatar
qman
Don't you gotta get it open to put in a new box?
Old Dec 23, 2015 | 12:18 PM
yetiman38237
I need a new box myself. Took mine out to fix hazard switch and route a speaker wire and it dang near disintegrated.......
Old Dec 23, 2015 | 12:37 PM
qman's Avatar
qman
Nothing wrong with getting a little new box.
Old Dec 23, 2015 | 02:06 PM
JEFFFAFA's Avatar
JEFFFAFA
You mean like this DC example? This one is the standard box. They also have the shorter one for rigs with factory A/C. www.dennis-carpenter.com.
[***************]PARTS[/COLOR]
[***************]CATALOGS[/COLOR]
[***************]Click for details.[/COLOR]
[***************]CLEARANCE[/COLOR]
SALES, DEALS, & DISCOUNTS
Zoom
<table class="table table-striped table-boxed"><tbody><tr class="odd"><th>Make</th><th>Model</th><th>Body Style</th><th>Notes</th><th>Year</th></tr><tr><td>Ford</td><td>Truck</td><td>F-Series</td><td>- </td><td>1967-72 </td></tr></tbody></table>
Review Summary
Our Low Price:$24.95 ea.
Glove Box Liner Assembly
1967 - 72
C7TZ-8106010-A
No Reviews
Be the first to review this product
  • 1967 F-100/750 1968-72 F-100/350 EXCEPT INTEGRAL AIC
StatusIn Stock
Sign In to Add to Wish List Add to Cart
Quantity
.imgBox:hover { -moz-box-shadow: 0 0 10px #ccc; -webkit-box-shadow: 0 0 10px #ccc; box-shadow: 0 0 10px #ccc; }
Old Dec 23, 2015 | 02:56 PM
yetiman38237
Yup.....that is the one.
460f250
13
Aug 15, 2019 07:15 PM
Scoop531
Nov 16, 2013 11:33 PM
IZZYAZ
Feb 5, 2008 07:50 PM
Shaman
1983 - 2012 Ranger & B-Series
Feb 12, 2005 09:31 PM
crowbar
Feb 16, 2003 11:53 AM
