Winter fuel additive?
Old Dec 18, 2015 | 02:15 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Originally Posted by white Buffalo
on a side note, I always have a bottle of this in each diesel in case of an emergency.
Better to also carry a spare set of filters than try to clean up frozen ones with 911. I'd only use the 911 to flush the fuel lines and if the tank itself if gelling up, not on filters. Replacement is too easy.
Originally Posted by jdw1
Power service ...some 911(as needed) as mentioned
If something does happen, DO NOT use the red bottle of Diesel 911 like a normal additive, as in just dump it all in a try to run the truck.
Read the directions on it, and mix it correctly 50/50% with fresh diesel and (if you don't carry spares) soak your filters with the 50/50 mix. Don't assume the fuel in the tank is gelled and just dump it into the tank; clear both filters, then check for fuel flow, THEN if the tank or lines have a problem start adding it to the tank until it clears. The wax crystals build up in the filters before the entire tank is gelled up requiring the full dose of additive, and the 911 stuff is hard on the fuel system if it gets overconcentrated.
(I'm sure you two know, but the guy googling this page this on the side of the road might be saved a set of injectors for reading the directions)
Old Dec 18, 2015 | 04:52 PM
navistarnut's Avatar
navistarnut
Originally Posted by 87crewdually
Next time I'm out west I'm going for the T-shirt. They better not be sold out.
There are a few other names in place of that we Midwesterners have come up with over the years, I won't mention them here lol.
socks262
24
Jan 9, 2014 09:28 PM
PrinceValium
6.7L Power Stroke Diesel
Jan 10, 2012 11:43 AM
ford7379trucks
Dec 11, 2009 10:29 PM
artfuldodger
Sep 16, 2007 10:44 PM
andywe
Sep 12, 2006 12:43 PM
