Block Heater plug ideas
Old Dec 15, 2015 | 11:26 AM
William Mark Brown's Avatar
William Mark Brown
I have the block heater and it just has the power cord dangling with a cover for the prongs. What are you suing and how well does it work with links if possible. My plug is hard to remove and the cold is rough on my hands so I am thinking something like this on my truck
Amazon.com: NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug: Automotive Amazon.com: NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug: Automotive
Just curious where I would mount it. I really don't want to cut a hole in my bumper. Anyone have ideas for a plate or different spot I could mount it? My truck seems to be missing the rubber piece underneath the bumper I would put it there. What about a plate where the tow hook is? I don't have fog lights so maybe there?
Old Dec 15, 2015 | 01:45 PM
F250_'s Avatar
F250_
Inside the wheel well in the liner, perhaps?
Old Dec 15, 2015 | 03:09 PM
Dan V's Avatar
Dan V
Marinco covered plug mounted in the front of the bumper.
Old Dec 15, 2015 | 03:22 PM
binuya's Avatar
binuya
A few years a go this member did the mod with a Marinco plug in his front bumper. Pic on post #9: https://www.ford-trucks.com/forums/7...rinco-mod.html
Old Dec 15, 2015 | 05:17 PM
SkySkiJason's Avatar
SkySkiJason
Sorry I don't have a better pic, but you can see my Marinco on the side of the front bumper.
~$15 at bass pro shops
Best part is ya don't have to put your coffee down to unplug!!
Old Dec 15, 2015 | 05:49 PM
CampSpringsJohn's Avatar
CampSpringsJohn
And that's important!
Old Dec 16, 2015 | 01:41 PM
William Mark Brown
I never have good luck drilling a hole into metal, like the bumper, without scratching or the cutter slipping. Any tips?
I would probably go with the plug on the side like SkyskiJason so that way I might not forget to unplug the truck.
Old Dec 16, 2015 | 01:48 PM
binuya's Avatar
binuya
Drill a pilot hole, then use on of these and go slow so you don't overheat and burn up the blade: http://www.tanshanomi.com/project-x/...e-hole-saw.png
Old Dec 16, 2015 | 06:40 PM
SkySkiJason
I just used masking tape and a hole saw. Be sure to paint the cut to prevent rust and chrome flaking.
Put a cord with a lighted end on plug where I have it and it's hard to miss - even covered in snow.
Old Dec 17, 2015 | 07:49 AM
William Mark Brown
Supposed to be 47 degrees this Sunday. I might try to order a plug and get it here in time. I can go buy a hole saw blade here in town. I ordered the plug and then a dewalt hole saw blade with the adaptor just because I needed prime shipping. $40 and it should be here Saturday.
What paint should I use on the hole?
Are the screws that come with the outlet ok or do I need different ones for the bumper? I will install mine on the drivers side of the bumper.
Old Dec 17, 2015 | 11:02 AM
SkySkiJason
I like rustoluem 'rusty metal primer' for stuff like this. The more coats the better!
No need for screws. The Marinco uses a big electrical knock-out type nut to fasten it to the bumper. The screws would help keep it from rotating, but I have never had that problem.
Old Dec 18, 2015 | 08:08 PM
lawdawg79's Avatar
lawdawg79
just park your truck in a heated garage like me and you dont have to worry about it
Old Dec 19, 2015 | 08:06 PM
Colorado350's Avatar
Colorado350
I'm thinking about mounting mine in the side of the bed above the fuel door using the
. Less likely to forget it's plugged in and I need to install a new heater anyway so I figure I might as well brain storm plug location too.
Old Dec 19, 2015 | 08:12 PM
F350-6's Avatar
F350-6
I've had my Marinco plug for years. Even drilled it into my Ranch Hand bumper using a hole saw from Home Depot. Took some time, and the hole saw wasn't worth much when I was done, but it worked.
Old Dec 20, 2015 | 07:43 AM
SkySkiJason
Originally Posted by Colorado350
I'm thinking about mounting mine in the side of the bed above the fuel door using the Amazon.com: NOCO Genius GCP1 Black 13 Amp 125V AC Port Plug: Automotive. Less likely to forget it's plugged in and I need to install a new heater anyway so I figure I might as well brain storm plug location too.
Not sure I'd like that location, but I dig the integrated cord on the NOCO unit! It looks like a better cap design than the Marinco as well. I put old injector o-rings on my Marincos to help them stay closed.
