HPOP Leak
Old Dec 14, 2015 | 01:44 PM
OBS Rock Lobsta's Avatar
OBS Rock Lobsta
HPOP Leak
Hello,
Do I have to remove my fuel filter and bowl to attempt a repair on my HPOP leak?
Thanks
Old Dec 14, 2015 | 02:48 PM
binuya's Avatar
binuya
Originally Posted by OBS Rock Lobsta
Hello,
Thanks
It depends on where the leak is. I had an o-ring fail on the plug at the bottom of the HPOP and was able to complete the repair without fuel bowl removal.
Old Dec 14, 2015 | 03:06 PM
William Mark Brown's Avatar
William Mark Brown
Yeah it really depends where the leak is located. if it's the end plug on the back then no. If it's the non serviceable plug or the C clamp then yes.
Old Dec 14, 2015 | 05:17 PM
sudsmcduff's Avatar
sudsmcduff
I removed and rebuilt hpop without removing fuel bowl. Although would have been easier with it out. There are videos from diesel Tech Ron on you tube.
Old Dec 14, 2015 | 07:41 PM
Beechnut's Avatar
Beechnut
I had the same thing......unfortunately I was not wise to the repair at the time and the dealer charged me 900 bucks for the O-ring fix on the HPOP.
Old Dec 16, 2015 | 01:22 PM
OBS Rock Lobsta
Thanks! I will look into it!
Old Dec 16, 2015 | 04:48 PM
jhl3's Avatar
jhl3
Exactly! I have done it both ways. Removing it is easier. Takes about 10-15 mins. If you remove it, just make sure you have the sleeves for the fuel lines on hand. Sometimes the old ones leak if reused. It would be a great time to rebuild it. Sleeves are included in the kit below.
Complete Fuel Bowl Seal Kit for Ford 7.3L (99-03) - GZ-7-003
Resendiz
20
Oct 16, 2016 05:07 PM
Fordby4
Aug 26, 2010 05:28 PM
2 stroke man
23
Mar 12, 2008 11:46 PM
Groundpounder0331
Dec 27, 2004 02:22 PM
